75mph vibration,who solved it?
Old Jul 22, 2021 | 05:42 PM
serb's Avatar
2017 GLS 450,Bmw Z4 35i
iv put new tires and like new oem wheels and its still there,i can only feel it in my seat,will take the car to a shop aug 4th to fix this,ill update if i fixed the problem.
Old Jul 22, 2021 | 07:20 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Typically it is a tire or wheel balance issue. The wheel may be slightly out of round. Are you running spacers or aftermarket wheels? Does it happen over flat roads only or on an angle? Have you measured your wheels for trueness?
Old Jul 25, 2021 | 12:46 AM
serb's Avatar
just seen this ad on facebook and asked the guy he has same car and same mileage so ill try this
Old Jul 26, 2021 | 09:13 PM
serb's Avatar
this did solve my problem,very happy,key is in matching high and low spots on tire and wheel so called road force matching,
i doubt they could do this at discount tire with their giggling teenagers
Old Jul 26, 2021 | 10:29 PM
BlownV8's Avatar
Yes, as stated earlier, that is typically a wheel/tire balance issue. Glad you got it fixed.
Old Feb 14, 2022 | 11:17 AM
gladerider's Avatar
GL450
had this nagging issue on vibration for a number of years.
the road force balancing did fix my issue as well. my local AAA autoshop has this machine. cost me $200.
i just replaced all 4 of my tires a few months ago and made sure that wheel alignment was done and the road force balancing was done on the new tires. now it floats like a feather.
Old Feb 14, 2022 | 03:05 PM
OnlyGerman's Avatar
Too many german broads
$200+ for a balance???
Old Feb 14, 2022 | 03:09 PM
gladerider's Avatar
GL450
if i remember correctly it was around $200. not sure if that included mounting of the tires. road force balancing is not cheap.
