Transmission lines campaign
Old Dec 30, 2021 | 09:48 AM
silvergl's Avatar
GL 450
I had my transmission lines blow up yesterday. I was told by an independent MB shop that there was a "campaign", not a recall, to get them replaced. Supposedly MB will cover the repairs for this item.
Has anyone seen this or have any info?
The car just stopped going, I pulled over immediately and it dumped trans fluid all over the road.
Any thoughts are appreciated.
Old Dec 30, 2021 | 09:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Did you see what part of the the transmission line failed? Hard metal pipe, rubber hose, rubber-to-metal crimp or an end fitting?
7G or 9G transmission?
Old Dec 31, 2021 | 09:55 AM
silvergl's Avatar
GL 450
Trans
I did not see where the leak was, there was so much fluid on the ground I just let the flatbed take it away. From the top, I could only see fluid everywhere. The connection at the radiator was intact
It's a 7spd, g7 I think.
Old Jan 4, 2022 | 03:05 PM
bha1's Avatar
2010 g
Do you have the invoice or part #'s of the lines they replaced? I'd like to proactively order and replace those parts on my GL.....
If anyone has a copy of the campaign, that would be helpful too!
Old Jan 14, 2022 | 08:11 AM
silvergl's Avatar
GL 450
Turns out it was the connection of the trans line to the radiator that had failed. They had to replace a clip to hold it back on. could have been worse I suppose.
Old Jan 14, 2022 | 08:17 AM
chassis's Avatar
2017 GLE350 4MATIC
Thanks @silvergl . Can you a copy of the service invoice referencing the campaign?
Old Jan 14, 2022 | 04:33 PM
silvergl's Avatar
GL 450
Campaign
I never actually found it, digging around and did not see anything. He may have been misleading me.
It was 7 qrts of fluid and the clip. Not bad.
Old Jan 14, 2022 | 06:22 PM
E55Greasemonkey's Avatar
This place is a joke.
Who previously replaced the radiator and didn't properly secure the clip? 🤔
Old Jan 14, 2022 | 09:25 PM
silvergl's Avatar
GL 450
Hilarious
Hilarious.
It made it >2k miles. Might also have have been my driving, nothing like rush hour on the parkway to raise the rpms. If it did not make it as far as it did, I would have been quicker to diagnose it.
Believe me, no one trusts my work less than I do. I'm sure end of the day I had something to do with it.
