07 GL450 very odd behavior - could be PCM? or?
However, last week it started doing something odd. When driving at about 45 MPH, ALL the dash lights flashed (and I do mean ALL - seatbelt light, etc - all of them), the car beeped and it auto-applied the brakes for a second. Within 2 seconds, all the dash lights cleared and it drove fine for the remainder of the 10 minute trip. When I got home, I looked it up and saw many posts saying that was the pre-collision assist and that it would happen on occasion and not to worry about it, so I disregarded it. This week, it started doing that again, but more often. It now happens about 75% of the time I drive it and along with it, the CEL popped on and the car started running very rough - felt like a misfire. I plugged in my OBDII and pulled the codes:
P0432: Main Catalyst Efficiency Below Threshold (Bank 2)
Pending Fault Log
P0302: Cylinder 2 Misfire Detected
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
P0629: Unknown code - More information may be available on the web
P0645: A/C Clutch Relay Control Circuit
P0942: Unknown code - More information may be available on the web
P0946: Unknown code - More information may be available on the web
P1596: Unknown code - More information may be available on the web
The following day, the same thing happened with the pre-collision thing, the dash lights and the beep, then the CEL and engine running rough. When I got home, I pulled the codes again, but this time they were different:
ECU reports no current faults
Pending Fault Log
P0308: Cylinder 8 Misfire Detected
P2610: M/PCM Internal Engine Off Timer Performance
Historic Fault Log
P0661: Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P1594: [BMW] B Camshaft Position Actuator Control Open Circuit Bank 2
Is my PCM going bad? Something else? Admittedly, I did bypass an O2 sensor about a year ago because the cats are pretty much dead due to mileage, but haven't had an issue with that.
Thoughts on what this might be?
