GL X166 Active Curve Sway Bar bushing replacement?
“Normal” MB practice is that the bushings are glued to the bar and not sold separately. Aftermarket non-OEM loose bushings may be available.
I ordered both struts to rrplace and the work is coming up this week.
I also checked the upper control arm, driver side is bad too. New parts also coming.
There is no point to replace just the bushings because the work you removed the entire part. I would rather spend a little more to have it pressed correctly.
Just some update.
Any solution for this???
