M278 Timing Chain Replacement
I've been told not to use an impact wrench on the crank pulley for this engine so I purchased the flywheel locking tool but can't figure out where to use it from the WIS procedure.
Do I remove the starter on the left side or is there access to the flywheel on the right side? The procedure seems to indicate there is a crankcase cover on the right side but I can't spot it from underneath the car.
Any help will be appreciated.
Thanks!
