MB replaced the cylinder head due to leaky valve
Old Apr 7, 2023 | 12:50 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
I'm not sure how widespread this info is, but MB extended the warranty for exhaust value issues on the M157 and M278 motors.
If you have a compression test failure / misfire caused by worn valve seats, at less than 10y and less than 120k miles, you could get a new cylinder head.
I just got my GL550 back from having this done, much better now.
Old Sep 19, 2023 | 02:32 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
I’ve been told by my dealer they won’t fix it until it triggers a CEL for the exhaust valve recall.
Old Sep 19, 2023 | 03:14 PM
mekantor's Avatar
Its more common in the SUVs from what I've been told. Do you have the typical misfire symptoms like vibration?
There might be a code stored in the ECU which Xentry can read. IT would say something like "the injector adjustment is beyond acceptable parameters" but it wouldn't necessarily misfire enough to store an OBDII code.
Old Dec 24, 2024 | 06:17 PM
patark's Avatar
S550
Great, another thing to think about. I just had a misfire and thought it was the coil. Luckily, I swapped the coil with another and the misfire changed cylinders. I wonder how you would know it is this vs just a coil issue.
Old Dec 24, 2024 | 09:07 PM
mekantor's Avatar
compression test would isolate it
