Oil Change
Old Apr 13, 2023 | 12:05 PM
NaviTimer1's Avatar
GL550
Oil Change
I have a 15 GL550 with 67K miles. I'm looking to change the oil myself for the first time on the GL and I'm looking for recommendations on the type of oil I should use.
I live in South Florida and temps are normally between high 80's F and low 90's F. The GL currently has 0W-40 but I'm thinking on switching to 5w-40 or maybe 10w-40 since I live in a very warm temperature were snow is never a factor.
What are you guys using on warm climates?
I appreciate any feed back, thanks!
Old Apr 13, 2023 | 12:10 PM
mtm's Avatar
mtm
gl450
I used Mobil 1 European Car Formula 0w-40 when I lived in NJ. Now I'm in Charlotte, North Carolina and use Castrol Edge Euro A3/B4 European Advanced Full Synthetic 5w-30 - it's on the list of approved oils for this engine.
Old Apr 13, 2023 | 04:49 PM
olesouthernboy's Avatar
2015 GL350, 2013 GL350, 2002 ML320, 1983 E300TD-D
I used Mobil 1 European Car Formula 0w-40 and still had scored cylinders so I do not know what to recommend. I believe the oil is good oil.
Old Apr 13, 2023 | 08:01 PM
frogger42's Avatar
gl450
I used Leichtlauf 5w40 from liqui moly, every three or four changes ill do the engine flush and ceramic additives as well.
Old Apr 14, 2023 | 12:04 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Go for 10w40, will have higher pressure, plus it is too warn in FL for 0w40 for the most of the year around. Normally it is recommended to use Mobil 1 European Cars oil.
