Converting a 2013 GL 450 to 2018 GLS 63 AMG (exterior)
I apologize however I am new to the forum therefore I hope I am posting my question in the correct section. A few friends and I have decided to upgrade my 2013 GL 450 4Matic to a 2018 GLS 63 AMG (exterior wise only). I have purchased all necessary parts such as the GLS 63 AMG body kit, front hood, headlights and taillights. Making the parts fit will not be an issue at all, since we have quite a lot of experience in putting body kits together and modifying exteriors.
Anyway, I am sure we are going to hit issues with the wiring diagrams for the headlights and the taillights, that is the reason I decided to put the question if anyone before me has attempted to perform such a modification. Both cars the 2013 GL 450 and the 2018 GLS have the intelligent lighting system, therefore it will not be a major issue to complete this task. So, having said that please let me know if anyone has done this mod and if you have can you help me with how the wiring diagram or connections have to work, especially for the headlights since they are our major hurdle for now.
Looking forward to your support,
Thank you,
Sounds like an interesting project, however, so I'll be looking forward to the end results.
FWIW, here's a MB conversion that may be of interest to you (not a SUV):
https://mbworld.org/forums/e-class-c...-e550-cab.html
If yours goes in let me know?
The GLS retrofit would be some job for the front end I expect but keen to see how this turns out.
I might start accumulating used parts if you can make it happen. I just haven't seen any posts about them yet so I don't want to invest until I know how others complete it.
Thanks!!!
arabam 2013 yıl GL350, gls gl farların güçlendirme, lütfen yardım beni götürdü.
Kablo şemasının veya bağlantılarının nasıl çalışması gerektiği konusunda bana yardımcı olun, özellikle de şimdilik en büyük engelimiz olan farlar için.
Thank you,
My question is - you mentioned you bought a body kit… do you mean you bought an aftermarket kit (complete) or did you build up a our own kit by buying the individual GLS OEM components? That’s what’s got me confused- I’m trying to find out if over the counter GLS63AMG body parts will bolt straight onto my GL550 or whether I need aftermarket parts and/or kit.
If it is such that I need an aftermarket kit, can anyone recommend one and perhaps share a link.
Thanks in advance
Simon
1. Can the conversion be do using all for mercedes gls new part changing wings, bonnet, front bumper front panel and bumper?
2. Would you purchase the cheap chinese conversion kit online will they fit well and good conditon. link attached. https://offer.alibaba.com/cps/m8irg4...=1600522536239
3. how would look at getting the headlight to work and what changes would need to do if i just want to replace with mercedes gls geniune parts.
thanks for your time looking at this guy would be great if someone could help with information regarding this new project of mine picture of the car below
with this year. Mostly find similar to what’s already on here. Any possible companies or websites that have a good selection of aftermarket nice looking grills? Also, on a separate note, I posted last week, but following up, I seem to be having an issue w my front seats and the massager adjustmentS on the command center, will not all of a sudden want to work. I try to adjust the numbers to, example, slow and steady, or change the sides, as I move the numbers up or down, it immediately goes right bk to 0. Won’t stay. They both worked till all of a sudden 2-3 weeks ago.? I’ve looked at fuses, connections, everything…am I missing something? Well, duh 🙄 of course I am! Jerez, sorry. Does anyone know what may be going on or had this happen? Thanks so very much! Y’all are wonderful!
