shudder while accelerating/load
Old May 5, 2023 | 09:58 AM
Rpeterson's Avatar
GL 450
My 2013 GL450 is in great condition but recently started shuddering as I accelerate or is under load going up a hill. I have looked at many online articles but it seems that there are many things it could be.
It ranges from a torque converter, CV joint, axle, transmission to a software update. Any suggestions?
Old May 5, 2023 | 10:50 AM
mtm's Avatar
mtm
gl450
If it feels like chain skipping teeth - then it's very common with older GLs. It's the chain in the transfer case that is stretched and skipping teeth. The solution is to replace the chain, the chain and the gear, or the whole transfer case with a rebuilt one.
Old May 5, 2023 | 11:36 AM
frogger42's Avatar
gl450
How does it feel when turning on? Smooth or rough? Could be engine mounts.
Old May 5, 2023 | 03:36 PM
Tiffany's GL450's Avatar
GL450
My wife's '13 GL450 started doing something similar to that. I jumped on it yesterday coming home and it sputtered and the SES light came on. Got it home, checked the code and it said 'MISFIRE, #2 CYLINDER'.
Got out, went to my tool box to grab some tools and came back to the car to read it again and the code was gone and it ran as smooth as silk. Drove it to work and used a Professional scanner and it too said #2 Cylinder Misfire but it was in the History file and not the Active File.
Got off of work, drove home and it did it again. Got up this morning to verify #2 Cylinder again and the code is gone and its running like a Champ.
I contacted a local Mercedes/Porsche/Jaguar shop and he said spark plugs or Coil Pack. The dealer replaced the plugs at 67K and the car has 96K. Sounds like a Coil issue, I'm going to replace the coils (plugs too since I will be there) and see if that fixes it. I just got to save up
Chad
Old May 5, 2023 | 03:48 PM
GL450
What is the firing order on this car? 1-4 on the Drivers side and 5-8 on the Passenger side?
Or something different?
Chad
Old May 5, 2023 | 10:54 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Could be oil in connectors or water in spark plug holes or lost of compression
Old May 6, 2023 | 05:26 PM
chassis's Avatar
2017 GLE350 4MATIC
Shuddering also reminds me of torque converter or lockup clutch problems. I would check ignition-related items first as arsupisemnet suggests.
Old May 7, 2023 | 09:39 PM
GL450
Does this Car have a Mass Airflow Sensor?
Does anyone know where it's at if it does?
Chad
Old May 22, 2023 | 10:54 AM
GL450
Fuel Injector fixed my Cylinder @ Misfire
Chad
