Alternator fix options?
Old Jul 10, 2023 | 03:43 PM
AkTech's Avatar
2011 GL350 (Sold), 2014 GL350
My 2014 GL350 just failed on me in the Oregon heat. No power. When I jump start it and remove the external battery pack it stalls and shuts down. I had a chance to take battery terminals Volts measurements before it shuts down - around 9 volts.
I assume my alternator dead... Begore i get a diagnostic results from the local dealer and they propose to replace it, at 2100 USD just for alternator!, is there anything i can suggest to them to try? Could that be a stretched/failed belt? Or a "voltage regulator"? Parts adviser says he can see a "voltage switch" in the catalog. Is that the same thing? I spoke to few people and they say there is no such thing as replacing voltage regulator on these vehicles. I really really hope it's not gonna cost me 3k in parts and labor to resolve this.
Any suggestions?
Old Jul 10, 2023 | 05:31 PM
oldmangrimes's Avatar
GL450
https://mbworld.org/forums/gl-class-...ery-light.html
I just did this, but it's a M278 gas engine and not the diesel so I don't know if you have the same alternator. It cost me hours of my time, but only a few bucks for the part. I'm in Oregon too.
Old Jul 10, 2023 | 05:51 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
its not 3k in parts and labor.
yourmechanic.com
buy your own alternator, wait for the guy to come install it. Some radiator hoses have to be moved so have a gallon of coolant handy to replace whats missing. when did you last replace the battery?
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jul 10, 2023 | 08:04 PM
AkTech's Avatar
yourmechanic.com - They quote just over 2k with refub alternator being around 1,800 USD
"when did you last replace the battery" - yesterday. It didn't help. The car drove for about 30 mins and died again.
Anyway, I am not local in OR, leaving the car at the local MB shop and flying back to Vancouver, BC and coming back in a week with a refub alternator that cost around 1K USD. Surprisingly it is cheaper in Canada. At least something is cheaper there!
And regarding the idea replacing just a voltage regulator, I wish I could do this locally in OR, but MB tech says - "you need a new alternator". There is no way for me to know if he tested the regulator or not. I might bring the new regulator and ask them to install this first and see if that works...
Old Jul 10, 2023 | 08:36 PM
SPONSOR
You could do just the regulator but later in life the bearing fails anyway albeit considerably later. My voltage regulator was failing but the bearing was also shot anyway. I see what you're going through. If we had more time to plan I could get you probably repaired for 1100 or so. On the older Mercedes it was possibly by only a few people to replace the voltage regulator, it has these spring loaded contacts that maintain contact with the alternator at all times, this device eventually wears down over time or degrades in performance from heat cycles. It's mounted on the back of your alternator which these days require you to practical remove and reinstall the alternator anyway. If you're paying the labor you might as well have a new alternator. I'm sorry the quote is so expensive up there, I'd shop around I can get this deal here and I live in one of the most expensive parts of the country. I also do this service for around this much. Use Yelp, "Mercedes mechanic", sort by reviews, call the top 3 and be done. Don't necessarily compete on price but how badly they want your business and time availability they're willing to make for you. If we can chop $1000 of the bill I would feel much better.
They don't do any real testing at MB, they just "fire the parts cannon" and you're on the hook for their trial and error in most scenarios. I'm pretty sure they're right this time. Shop, call around. The alternator install on that engine isn't particularly pleasant but a good shop can get it out for $300 in labor and they're going to sell you a Bosch reman alternator for around $500. If price isn't the issue just leave it at the dealer and call it done. Making $400+ for a couple hours of work is a decent deal for any shop.
__________________
Old Jul 11, 2023 | 11:23 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Buy oem like that and pay labor https://www.autohausaz.com/pn/OE-0009062700
Old Jul 12, 2023 | 03:40 PM
AkTech's Avatar
It is a wrong one. X166 alternator is around $1.5k USD refab and $2,100 USD new.
Old Jul 12, 2023 | 03:47 PM
Wrong again,
Amazon Amazon
that one for diesel he has. I would just swap regulator before changing whole unit.
Old Jul 12, 2023 | 07:05 PM
AkTech's Avatar
Wrong again, https://www.amazon.com/Valeo-439891-.../dp/B078HH8W37 that one for diesel he has. I would just swap regulator before changing whole unit.
This one seems correct fit! Thanks a lot! I have cancelled my original order and ordered this Valeo alternator from Europarts. It saved me $700+ CAD.
Is voltage regulator a part of alternator OR an additional piece? Meaning by installing new alternator, do I get new regulator as well?
When I spoke with MB dealer parts guy, he says he can see "volts switch", but no such thing as the regulator. Is that the same thing?
Old Jul 12, 2023 | 07:24 PM
MB Dealer interested making profit on you sas. You can pull black cover off your alternator and change something looking like this https://www.fcpeuro.com/products/mer...leo-0041541206
Old Jul 12, 2023 | 08:06 PM
AkTech's Avatar
I would, but my vehicle in Oregon at a dealer and i am back in BC. Next time
Old Jul 13, 2023 | 03:17 PM
SPONSOR
yeah your new alternator comes with a new voltage regulator. it's job it to keep you running at 14.7 while charging and 12.whatever while youre running
__________________
