2015 GL550 cylinder scoring
My question is, does the extended MB warranty on the "Emission Extended Warranty – Exhaust Valve Assembly" from March 2023 or the LI01.30-P-061835 TSB would cover the scoring issues?
https://mbworld.org/forums/attachmen...-m278-m157.pdf
https://mbworld.org/forums/attachmen...1835_ver_1.pdf
Thanks in advance!
Will probably never buy another MB again, exp considering the X7 is available now.
BMW has its own issues as well. Nothing's wrong with a Honda pilot or Acura MDX.
On my original issue with the oil in the harness they found that the root cause for the misfires is an internal short in the coil for cyl 1 and that was blowing fuse 217, not the oil in the harness. Since all the cams for bank 1 were on the same circuit they did not have power supply. After replacing the coil the car runs fine.
