NEED HELP-will this transfer case work for my GL550?
Old Oct 30, 2023 | 06:12 PM
Gerald480's Avatar
Mercedes GL550
Guys, finally got some numbers.
$1500 for chain swap labor, seal and fluid. I pay for the chain
or $800 labor for transfer case swap. I can get a transfer case for $600, apparently low miles but who knows. So total around $1400
what would you guys do?
Old Oct 30, 2023 | 08:18 PM
350gunner's Avatar
GL350
Chain swap. I would say better than 50-50 that if you put in a used transfer case you will need to chain swap within 10-20K miles. All transfer case chains seem to go bad at some point.
Also, opening the case and swapping the chain is at most 2 hours labor and a tube of RTV. Why is there a $700 upcharge for that?
Old Oct 31, 2023 | 12:11 AM
Gerald480's Avatar
Mercedes GL550
I have no idea. They’re the only shop who quoted me. I called about 5 different transmission shops who told me they won’t even touch the chain. They would rather swap the whole case.
Old Oct 31, 2023 | 08:23 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Price comes with name. Either way you can do it yourself, seems like you might have more knowledge that most of the parts swappers
Old Nov 2, 2023 | 01:38 PM
Gerald480's Avatar
Mercedes GL550
I definitely can’t by myself. I’m not mechanically inclined.
I did however find a shop that can swap the chain “as long as it doesn’t need any special tools” and turnaround time is 2-3 days and cost was around $200.
The issue is he won’t remove the transfer case and put it back, I would have to walk in with the transfer case.
so I would have to find a shop to pull it out and install it after the chain is replaced.
this is a headache
Old Nov 7, 2023 | 02:25 PM
Gerald480's Avatar
Mercedes GL550
Hey guys I ended up getting a rebuilt one off eBay.
Other than the shell 1 qt of transmission fluid posted above, what else would I need? I want to provide everything to the mechanic to complete the swap.
thanks
Old Nov 7, 2023 | 03:34 PM
  #32
mtm's Avatar
mtm
gl450
You'll just need the fluid
Old Nov 7, 2023 | 05:46 PM
  #33
Gerald480's Avatar
Mercedes GL550
perfect thank you
