2014 GL450 B275113 Passenger side seat mounted squib 1 control circuit open
Old Nov 20, 2023 | 01:44 PM
fahrizaqeel's Avatar
2014 GL450
After changing the battery under the front passenger seat in my 2014 GL450 I am getting this error code B275113 Passenger side seat mounted squib 1 control circuit open. I tried to clear it using the scanner but it always stays on. any idea?
Old Nov 21, 2023 | 04:23 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You go under the seat to deal with battery and now a fault is pointing at what is likely a bad connection under the seat.
The SRS connectors are usually made reliable. Beware that you may trigger an accidental deployment if you decide to go past a visual inspection.
