2014 Gl450 blowing fuse 215
2014 Mercedes Benz Gl450 w278? x166?
Hey everyone. My gl450 is blowing fuse 215 under the hood. I found that it is engine compartment / engine pin 7. I am hoping someone has the wiring diagram or knows where this pin 7 is. Thanks in advance
I have a feeling pin 7 goes to cylinder 5 coil. Through some methods that are less than suggestable, I tracked down that cylinder 5 coil was shorting and blowing the fuse. And melting. New coil coming. I'll update after I get more fuses and new coil
Hi were you able to resolve the 2014 GL450 blowing fuse issue? I am having the same issue where blown fuse #215 (15 Amp) leaves no power to bank2, ignition coils 4, 5 and 6. Was this related to the bad ignition coil(s) or wiring harness isssue?
