Broken hose/pipe/housing - 2016 GL450
Old Jun 8, 2024 | 08:12 PM
mmeister22's Avatar
GL 450
Hi there. New to the forum and appreciate any help in trying to find the part number and where this broken PVC type (I think) goes from this housing.
It’s on the from driver side of the engine and is located just below and left of the oil filter housing in the photos.
Coolant was leaking out of here.
i can’t find anywhere else where there is hose/pipe missing! Do you know what this is called or what the part number might be?
Old Jun 9, 2024 | 08:06 AM
chassis's Avatar
2017 GLE350 4MATIC
Follow it back to where it connects. Small diameter suggests coolant breather tube, windscreen fluid heater or other low flow/low heat rejection purpose.
You have alot of oil leaking from the common front cylinder cover leak. Maybe other leaks. Clean away all of the oil crust, find and solve your oil leaks.
Old Dec 26, 2024 | 10:19 PM
stuckonthefloor's Avatar
Broken Hose
Did you ever figure out what it was or the part number?
Old Dec 28, 2024 | 10:16 PM
keekahn's Avatar
2016 GL450 X166
[QUOTE=stuckonthefloor;9086750]
Hopefully I can help. I am pretty certain the part number the hose assembly is 166-500-88-75. Broke on my 2016 GL450 in the exact same place almost a year ago. The part cost me $49.50 and it was pretty straightforward to replace after figuring out the part number. The tricky part of the replacement is that one end on the hose assembly snakes into the left wheel well where is attaches to a small electric pump. I took the left driver's side wheel, removed the fender liner to get to that part of the hose assembly.
