2014 Mercedes GL 450 start up
Old Sep 19, 2024 | 09:06 PM
OurMercs's Avatar
We own a 2014 Mercedes GL 450 and a 2012 Mercedes E350
Hey guys! Long time reader, first time post. My 2014 GL450 sounds rough on start up. No grinding, ticking, or rattles, it just sounds rough? Is this just a GL thing? (My E350 sounds like a normal car)
Thanks in advance!
File Type: mov
Old Sep 20, 2024 | 08:39 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Hard to tell anything from the video but your 450 is a bi-turbo V8 and the 350 is a 6 so they will sound different. Are you using excessive amounts of oil in the 450?
Old Sep 20, 2024 | 04:48 PM
OurMercs's Avatar
Thanks for the response! I don’t think I am, I just wanted to make sure I wasn’t hearing any phantom noises that plague other GLs!
I get the oil change done per the Manual. I never miss and never go over. Meticulous maintenance!
Old Sep 20, 2024 | 05:09 PM
BlownV8's Avatar
The early M278's are plagued with engine failures. How many miles?
Old Sep 20, 2024 | 06:41 PM
OurMercs's Avatar
She’s got 158k lol
M278 is the engine model?
Old Sep 20, 2024 | 08:17 PM
BlownV8's Avatar
Originally Posted by OurMercs
She’s got 158k lol
That's great but it doesn't change the fact the M278's are known to fail but glad yours is doing OK. Hope you see 300k or more.
Old Sep 21, 2024 | 03:04 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
OILING MATTERS....
You can easily improve the odds of survival with oiling improvements.
Use a better oil for less miles.
The stock setup is not entirely biased for longevity.
This is somewhat vague so you do topic research and in case your engine pistons are beginning to produce shavings you do not associate that to a specific oil aside from thin stock.
All oils are good but some better than others, including cheaper ones.
Old Sep 21, 2024 | 11:38 AM
OurMercs's Avatar
Thanks! I’ll look into this and change my oil changes up. Is twice a year better? Or even more than that?
Old Sep 21, 2024 | 01:58 PM
CHEMISTRY & VISCOSITY MATTER...
You know... 10kMi oil interval recommendations are not entirely in your engine best interest.
Old oil is acidic with poor viscosity that limits pistons cooling.
This causes dirty rings to get jammed by burnt oil carbon.
Quarts of oil get vaporized into intake by high blow-by pressure to coat intake valves.
Oil+filter change once a year or at 5kMi or as soon as oil is burnt into black sludge.
