2014 p0391 & p0392
Old Nov 16, 2024 | 12:09 PM
sst0003's Avatar
2014 GL450
2014 p0391 & p0392
2014 GL450, 130k Miles. On the way to work car dies will not re-start and throws the codes.
I have swapped the cam sensors bank 1 to bank 2 to see if the error followed the parts & it did not. I replaced the bank 2 sensors with the new green o-ring, no change. Cleaned the connectors which were covered in oil and found some out of place electrical tape. Pulled it back and found the following. I am going to clean / retape, but now I'm nervous about subsequent issues.
Questions:
A - Would this be enough of an issue (tape is old/brittle and looks like 2 different wires are involved) to throw a code?
B - Is there a part (like the sacrificial pig tail for the prior model) where I can get some source wires to splice a new connection?
Any advice would be appreciated. We've loved this thing and driven it daily for six months with no real issues.
Old Nov 17, 2024 | 07:56 PM
sst0003's Avatar
2014 GL450
Update
Questions:
* Pulled the ECM, oil has not wicked its way all the way through. Cleaning the connections. I've searched the threads and there's no real resolution I can find except replacing the Cam Sensors. Then it seems to jump to harness replacement. Is there an in-between?
Old Nov 20, 2024 | 06:42 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
That is not a reason for car not to start. I have dead cam sensor in mine, just too much things to do, no time to replace.
Old Nov 20, 2024 | 08:10 AM
trigital's Avatar
W213 All-terrain
When cables is short circuited, the power supply for low voltage sensors inside the ECU will be stopped and this could be the reason for car not starting.
