Broken coolant part. Please help
Old Nov 30, 2024 | 02:00 PM
MattsGL450's Avatar
Long time lurker but I never needed to sign up, until now.
On the way back from the airport on Wednesday night I caught that distinct smell of coolant in the cabin and then the temp started to drift upwards. Long story short I immediately pulled over and realized I had a leak. After closer inspection today, and after removing the reserve lid, I could tell water was leaking out of the attached part. Looks like the plastic has broken off inside the hose. Unfortunately, I can't find this specific part as I don't know exactly what it is. Any help is appreciated.
Thanks!
Details: 2014 Mercades GL450
Old Dec 1, 2024 | 09:54 AM
MattsGL450's Avatar
Bump
Old Dec 1, 2024 | 02:19 PM
Jim Ma's Avatar
S 550, S65 Coupe
It’s a Turbo Coolant line. Goes to the drivers side Turbo
Old Dec 3, 2024 | 10:53 AM
Yeffsy's Avatar
2015 GL350 Bluetec
I've got the diesel so I'm not familiar with your engine, but I think you can find what you need by doing the following:
-go to: https://www.fcpeuro.com/
-enter your vehicle
-on the right there is the categories. You need to go to Engine, Turbocharger, and then Turbocharger Coolant Line
I'm not sure exactly which one you need, but I think you're looking at less than $100.
Jeff
Old Dec 5, 2024 | 06:16 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
more info
here is some more info
https://mbworld.org/forums/gl-class-...668304096.html
Old Dec 5, 2024 | 06:21 PM
vesiadog's Avatar
video help
google youtube mb 166 turbo coolant leak… it won’t let me post the ones I found ???
