Red battery symbol?
im getting a red battery symbol on my 2013 GL550 and while driving it will even turn the power off to my radio. I believe it says “command center turning off”
Do you guys think it’s the battery or alternator?
I believe the battery is still the stock one so it’s never been replaced.
*Just found out the passenger seat motor is faulty. Only one side moves forward and backward so I can’t access the 2 bolts in the back to remove the seat with a socket. I can get a 10mm wrench in there but no way I can loosen with the seat track in the way.
Is there a way to physically slide the seat forward?
Really need help with this one.
thanks in advance
thanks in advance
Here’s the fun part which I’ll add to my op.
The seat won’t move up all the way for me to access the battery because one side is faulty. When I move the seat forward, only one side moves so it goes on an angle. I tried accessing the bolts with a wrench but can’t grab the bolt without hitting the track which eliminates me to loosen them.
I don’t know what to do here. I thought about ordering a motor and replacing but I was told the seat has to be removed in order to do that.
Do you have any suggestions?
The seat cushion comes out fairly easily once you unscrew the brackets at the front. Once the seat cushion is out you can see the motor for the seat adjustment and in my case the rod broke and I was able to manually turn the rod for the side that was stuck to move it forward and back. I replaced the rod, made it with stock square steel rod and was back in working order. If you mentioned that 1 side is working, then the motor may not be the issue. Once you have the seat cushion out you may be able to see the reason for only 1 side working.
Good luck.
I would not only replace both batteries due to age, but by starting with the aux you may fix some of the odd electrical behaviors you are experiencing. Failures of the radio and seat motors simultaneously would certainly check the “odd” box.
I think it might be the alternator so I’m getting it towed tomorrow to the mechanic. Hopefully it’s just that for now, but I’ll have him look at the both batteries to see if they need changing too.
I’ll keep you guys posted.
thanks again!
thanks again!
thanks again!
You should still go ahead and replace both batteries IF they are original. 12 years was a great run and they are beyond their expected lifetime. A bad AUX battery will give you endless grief so it’s reasonable to stay ahead of it. A bad main battery will simply manifest as needing a jump start.
I think I’ll just wait it out. Thanks for your help
