GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
brake squeaking
Old Sep 28, 2015 | 08:11 PM
cyclrder's Avatar
18 E63s Wagon 15 GL63 (sold), 10 Turbo TT MT, A36 Bonanza, 20 JLU Rubicon
brake squeaking
I'm having brake squeaking all the time ... anyone else?
Old Oct 6, 2015 | 10:11 PM
smayshusband's Avatar
2004 E55 AMG 2014 GL63 AMG
I was getting some squeaking after about 20,000 miles. Sent in for service and needed all rotors and pads replaced. No longer squeaks.
Old Dec 8, 2015 | 07:02 PM
Hegone's Avatar
Mercedes GL63 AMG
Sorry for the old bump but do you mind me asking how much was parts and labor to get all brake pads and rotors changed out? I'm in the boat to buy new brakes front and rear right now and wanted to know how much it will be... Thanks
Old Dec 12, 2015 | 10:09 AM
Labor was $839.25, parts were $1593.64. This also includes an oil change.
Old Dec 31, 2015 | 03:09 PM
Hegone's Avatar
Mercedes GL63 AMG
Got the front pads and rotors done and rear pad also.. dealer told me that my rear rotors were still good.. paid 1300 with labor and parts.
I thought that all rotors and pads needs replacing??
Old Jan 1, 2016 | 11:11 AM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Rotors need replacing if they are damaged because the pads were complete worn and you had metal to metal contact or because of use wear. Usually the car will tell you if rotors are worn enough that need replacing via a brake service needed message.
Old Oct 22, 2018 | 11:12 PM
ashleyandjack's Avatar
Toyota
Same issue.
Old Oct 24, 2018 | 06:18 PM
UNderdog's Avatar
S65 GL320CDI GLS63 80 Series Landcruiser
I had really bad squealing (GLS63) and did the front pads (rotors were fine) and no more noise. So maybe its low front pads? Maybe it will come back in time as the pads wear. Not sure. My S65 will start squeal occasionally and if I clean out the brake dust it goes away. Didn't seem to help on the GLS though.
