GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
305/40s on stock 22 in wheels?
Old Apr 5, 2021 | 10:03 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Ideally you want the diameter to be the same or very small difference. You're at 30.7" and 30.9".
https://tiresize.com/comparison/
Old Apr 5, 2021 | 10:22 PM
Nyc_F's Avatar
2013 GL450
Running staggered on the 2013 GL450 will it be any issue I am new to Mercedes world just wanted to ask your opinion as I read most off the comments from chat members like you and others,Thanks in advance.
Old Apr 5, 2021 | 10:51 PM
Chedman13's Avatar
staggered doesn't matter - stock wheels on certain AMG's are staggered for example. The rolling diameter just needs to be the same or else you throw off your sensors and can harm your AWD system and also cause failure.
I don't want to say a definite yes or no because I don't know the tolerances. A difference in tire wear could make that difference, but I wouldn't do it. If you want to run two different tire sizes that's fine - just find two that have the same overall diameter.
Old Apr 7, 2021 | 07:54 PM
GreasySloth69's Avatar
CLA45 GL63
22 x10.5 square.
3mm spacer to clear front brake
295/30/22
Old Apr 8, 2021 | 09:38 PM
SeattleIS300's Avatar
ML 350, GL 450, GLS 63
I'm trying to figure out how much of the car I need to Xpel to protect from rock chips if I move to 305/40/22 Tires. @jargoude do you mean the portion by the quarter or is it on the doors as well?
Old Apr 8, 2021 | 10:23 PM
jargoude's Avatar
2016 Jaguar Ftype R and 2017 GLS63
I would do the lower portion of the door right above the running board section and the rear bumper to the right and left of each rear wheel. I am not sure how the progression would look as to where to stop the Xpel on rear bumper. Maybe have the entire rear bottom half of bumper protected to make it look un noticeable.
Old Apr 14, 2021 | 07:25 PM
  #32
fatmatt0116's Avatar
GLS
Will 285/45/22 fit oem rims?
Old Jul 9, 2021 | 06:21 PM
  #33
Had the Michelin 305/40/22 test fitted today on the stock 22” wheels and they rub on full lock.
Decided against them since it’s my wife’s car and will likely just get the 285/40/22 again.
