GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
2015 GL63 Center Channel Speaker Updated
Old Jul 29, 2021 | 09:26 PM
Scott2016's Avatar
2015 Mercedes GL63
Massively easy upgrade. Slightly better staging after upgrading the center speaker.
Specs on the original:
1) cover pops out, and speaker also pops out with no screws
2) it’s a 100mm dual voice coil speaker, and each coil is 8ohms
3) one coil plays audio, the other coil is separate from the audio system and plays the mbrace audio
coil with blue plug is stereo audio
light gray wire -
light gray black stripe wire +
coil with white plug is mbrace
gray black stripe +
brown black stripe -
made an adapter out of abs for a 100mm Scanspeak Discover 8 ohm mid range speaker for audio
added a 1 inch full range 8 ohm speaker for m-brace
(all purchased from Madisound)
Old Aug 24, 2021 | 10:24 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
did you have the b and o or hk system?
Old Aug 24, 2021 | 11:38 PM
Scott2016's Avatar
2015 Mercedes GL63
B/O
Old Aug 24, 2021 | 11:39 PM
corkshoppe's Avatar
Top Answer: 1
Originally Posted by Scott2016
B/O
I read your other post about the tweeters. Thx.
