GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Windshield washer fluid tank
Old Jan 27, 2024 | 07:59 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Anyone know the process for changing the windshield washer fluid tank/pump for the GL63? There are two bolts hold the tank to the car. One is on the lower left side of the passenger side fender well as you are looking at it and one is directly above where the top of the tire would be oriented. How is the filler neck removed? Is it held by friction? The pump keeps getting clogged and I need to pull the tank off to flush. I've tried vacuuming it out with a wet dry vac but it keeps getting clogged when I try to activate the washer pump.
Old Feb 20, 2024 | 09:33 PM
BlownV8's Avatar
Seems to be held on by tabs that will separate when you pull hard. My windshield pump gromet/filter was plugged by windshield wiper goo. Took it out, flushed it out with hot water and reinstalled. Works like a champ. Hope it is good for another 10 years.
