GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Mercedes gl starting issue
Old Feb 23, 2024 | 06:29 PM
Ryanrec's Avatar
2013 Mercedes gl350
I was driving my 2013 Mercedes gl on the motorway when it randomly cut out and after pulling onto the hard shoulder it would not start or even crank over. I tried to turn it back on but it just wouldn’t crank at all. There was no notification while I was driving to say there was a fault no noise no lights and the temperature was sitting at 90 as it should and it just shut off.AA told me engine is seized however I’ve had a mix opinion by many machine saying the engine on these don’t
seize without a big fault .If you have any idea what is wrong with it please get back to me.Im looking forward to the reply’s
Many thanks
Old Feb 23, 2024 | 07:48 PM
lh713's Avatar
2015 GL63, 2015 S550, 2006 SL55
Consider that it may be a bad crankshaft position sensor. Pretty easy to fix yourself.
Old Mar 2, 2024 | 10:25 PM
roadtalontsi's Avatar
10 C six trizzle
this is very far from something that can be diagnosed over the internet. Also it shows you have gl350, so im assuming it's a diesel. Likely has the warranty extension stuff. a crankshaft sensor wont prevent the vehicle from cranking. You're also in the GL amg forum section.
