GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
2014 gl63 amg 80,000 mile major service needs
Old May 11, 2025 | 08:19 PM
sanddanw's Avatar
GL63 AMG
2014 gl63 amg 80,000 mile service recomrmdations
I purchased a second owner gl63 amg that has been serviced every 5000 miles by a non Mercedes mechanic. No issues leaks or codes therefore none of the Mercedes recommended services besides oil n air have been completed. What are the majors that need done asap?
Old May 11, 2025 | 10:53 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Do the plugs and coil packs. Oh, almost forgot, proactively replace the Ebrake as it will seize/stop working and leave you stuck.
Old May 11, 2025 | 11:15 PM
sanddanw's Avatar
GL63 AMG
the other items I’m planning on:
serp belt
cam magnets
cam magnet wire extension? Not sure where to get?
turbo cooler lines (3)
motor mounts but not sure if it’s required?
Old May 12, 2025 | 07:43 AM
BlownV8's Avatar
Yes, engine mounts will be going out soon, you can guarantee that unless they were already replaced. Yes, turbo coolant lines is also a good idea as this is about the time they go out. Cam magnets are a good idea as well as the pigtails. I have a set I purchased a long time ago and just need to get around to installing them. Yes, I've been playing with fire. I think I got them on FCP Euro or Ebay. You also may have to unplug the wiper reservoir filter as the wiper fluid forms a gummy consistency and will clog the filter.
Old May 12, 2025 | 08:25 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Open your hood....if it has coolant in it....yeah, replace that one. We have also done every fluid (ours is about the same miles but a few years newer - same engine). We also replaced motor/trans mounts.
