GLA Class (X156) Produced 2013-2020
Replacement run flats for gx ssr or non run flat experiences for better ride??
Old Mar 12, 2020 | 04:22 PM
Wantboost's Avatar
Cadillac
I have conti gx ssr . Anyone replace theres with something else . How much better was ride quality if any ??
Old Jun 29, 2020 | 02:09 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
Nokian sells some excellent tires for dirt cheap. Check EBay for your size, and you'll see the Entyre and Entyre 2.0, also the Zline which is a performance tire that still has an all-season compound. I use them on my convert for 3 seasons. I use the Entyre 2.0 on my Audi Avant, it's one of the best made. The regular Entyre is an excellent go-to that I used on many different cars....never a problem.
Conti makes General, their excellent RT43 is great in snow and good wear. BFG is making some great tires now, owned by Michelin.
I would stay away from the SSR or any run flat. I carry a pump for most slow leaks and a plug kit. Good to learn how to plug a tire, you can do it still on the car in many instances. Keep pliers with it to pull out a nail, plug it and go.
Z-line extra XL load at 101 $450 235/50R18 AA wet rating https://www.ebay.com/itm/4-Nokian-ZL...s/313119816948
Entyre 2.0 $486 ride will be excellent as well as durability. https://www.ebay.com/itm/4-Nokian-eN...s/313108996828
Generals $579 great 700 wear rating https://www.tirerack.com/tires/tires...0&autoModClar=
Another General, sportier, not as good in winter, not as good wear.... AA wet rating
The BFG Comp-2 a giant killer. If you want the best, this is it. https://www.tirerack.com/tires/tires...0&autoModClar=
If you have a more specific question, let me know. Any of these are excellent choices.
Here's a Tire Rack test of the General GMax vs BFG https://www.tirerack.com/tires/tests...y.jsp?ttid=253
Old Jun 29, 2020 | 02:11 AM
This channel is excellent. Trust me on the Nokains.
Many of the tyres he reviews are not YET available in the US, but it's a look ahead. We get these tyres a year or two later.
The Vredstein Quadtrac he mentions is now available on Tire Rack. Not bad for wintery driving. https://www.tirerack.com/tires/tires...0&autoModClar=
This is a good test, Goodyear Weatheready is one of the best, not cheap though... https://www.tirerack.com/tires/tests...y.jsp?ttid=231
$800 and $100 rebate https://www.tirerack.com/tires/TireS...dex=0#allTitle
Eagle Sport are good, get it down to $600 https://www.tirerack.com/tires/tires...0&autoModClar=
New Kumho $425 tests well, AA wet rating def worth a shot in the price range
The site>> http://www.tyrereviews.co.uk
Old Jun 29, 2020 | 08:46 AM
Huey52's Avatar
2018 GLA 250
I haven't had to swap out GLA tires as yet, but have about 2 years now on Michelin Pilot Sport A/S on my Audi. If you don't need dedicated Winter tires in your area their all seasons are capable, comfortable and quiet. Mid-light snow, but more often sleet/slush in my region.
But I have to say the OEM Conti run flats are much better than I had anticipated. No complaints from my wife either, which is Huge.
