2018 GLA250 4MATIC rear tire ginding sound when acelerating or turning corner
Estimate
Final Invoice of service preformed
Last edited by LTK; Sep 9, 2022 at 07:16 AM. Reason: invoice was incorrect for service performed...this invoice was for the crankcase valve replacement not the differential replacement.
Estimate
My guess as to what is happening, is that some part of the differential is breaking down, resulting in debris interfering with the gears, causing the rumbling. Flushing the fluid has removed the debris, and probably slowed the rate of break-down.
As a side note, does using eco-mode disable the AWD? If so, that would stop the issue.
Also, the AWD does not turn off in the dynamic select drive control of ECO mode. To my knowledge, only the mechanic can disable the AWD, which as I mentioned stopped the grinding, but then I had no AWD. Living in the Northeast, I really want the AWD. If I lived in the South with no snow, and the differential broke again, I would consider just disconnecting, and keeping the car without. The fix is to expensive again, so the fluid change now is the only cost effective thing to do.
Once the AWD is disconnected, no noise or grinding. It only takes 10 minutes for them to do this, so I hope the dealer will help you out and not charge you. Please let me know, as it will help all of us with this very costly, known MB defect. Easy test to do before a costly repair! Thanks!
