GLA Class (X156) Produced 2013-2020
2015 GLA250 ISSUE Need Help
Old Oct 19, 2024 | 03:38 PM
tlavoie87's Avatar
15 Gla250
hello so i have a 2015 GLA250 4matic with 94k and it died when at a light engine shut down and cant restart.. when i key cycle it it cranks for about half a second then warning messages agout 4matic disable and unable to shift also the wite window around the PDRN disapears.. had it towed back to the shop and have a few codes i cant seem to figure out i cleared them to get a fresh code list and here is the list that comes right back..
AWD -
u010187
u041681
ECM
u010187
u010387
ES
u010087
ESP
c037100
c054100
c06a100
c038500
SCM
u010187
RFK
u10187
to me it sound like a can issue i checked voltage at the bus on drivers side to tcm and have 2.0 on high side and 0 on low side .. is the TCM bad? ANY IDEAS?
THANKS
Old Oct 20, 2024 | 06:37 PM
190Efan's Avatar
1991 190E 2.3
Have you checked the voltage for both the main battery and the auxiliary battery? Low voltage for either of these batteries can cause strange things to happen.
Old Oct 20, 2024 | 06:41 PM
tlavoie87's Avatar
15 Gla250
main battery is good ..I have not checked the auxiliary battery will check tomorrow.. appreciate the response
