GLA Class (X156) Produced 2013-2020
Random CEL, dash lights, totally blank dash help needed
Old Nov 7, 2024 | 01:33 PM
Dr.Ron's Avatar
C7 Z06
My step daughter's 2018 GLA250 with about 110,000 miles. Battery was replaced approximately 3 months ago. Car drives fine!
Put my scanner on and got code P06DA00-actuation of the valve of the oil pump in the engine has an electrical fault or open circuit. I've gotten this code 3x when the dash lights lit up like a Christmas tree, which happens often and randomly. The screen recently started to go blank also, then it comes back on. The gauges don't work, then they do work. Total gremlin!
I've seen another thread on another forum that says the dash issue is a canbus behind the instrument cluster. They wrote it's a quick at home fix.
I'm concerned about the oil pump code but I've read that this can be ignored.
Anyone have any experience with what I've written above?
Thanks in advance..Ron
Old Nov 7, 2024 | 02:14 PM
trigital's Avatar
W213 All-terrain
P06DA00-actuation of the valve of the oil pump - can be ignored, there are a lot of discussion around here about the valve from oil pump. This fault code does not cause check engine light, check engine light has to be because of some other issue. Open circuit, means that the valve will not be actuated anymore, so the oil pressure will me at maximum all the time.
https://mbworld.org/forums/mercedes-...ification.html
i would heck the battery ( should be young and AGM), the big yellow screw from the engine compartment where the battery negative is screwed at the chassis and of course the CAN Bus distributors behind the dashboard for water ingress..
W205C43PFL's Avatar
I recommend reading these threads:
https://mbworld.org/forums/gle-class...t-p06da00.html
https://mbworld.org/forums/mercedes-...es-me-cel.html
https://mbworld.org/forums/w212-amg/...solenoids.html (this one is a long one so read the first page faq at least)
Old Nov 7, 2024 | 02:17 PM
W205C43PFL's Avatar
I also recommend OP checking the aux battery, although I can't remember if the GLA has one.
Old Nov 7, 2024 | 02:42 PM
Dr.Ron's Avatar
C7 Z06
Thanks!!
Old Nov 8, 2024 | 12:07 PM
190Efan's Avatar
1991 190E 2.3
My understanding is that the GLA does have an auxiliary battery. I think telling the OP to check the auxiliary battery is good advise.
Old Nov 8, 2024 | 12:47 PM
W205C43PFL's Avatar
I see, thanks for confirming.
Old Nov 19, 2024 | 03:36 PM
Dr.Ron's Avatar
C7 Z06
UPDATE:
So yesterday I installed a new auxillary battery and a new canbus behing the instrument cluster. Both were very easy to do. The battery took me about 5 minutes and the canbus swap took about 40 min. If I had to do the canbus swap again I bet I could do it in about 15 minutes.
I also reset the tire pressure reference amount since we're going with the pressures on the inside of the gas cap door instead of what is on the door jab sticker. Without resetting the reference pressure and using the lower pressures we were intermittently getting the low tire pressure light. Those door jam pressures Mercedes says are normal will rattle the fillings out of your teeth!
As I've mentioned in the lead post of this thread, the car is my step daughter's so we'll have to wait for her to drive it a few times to see if these remedied the Christmas tree of dash lighrs she kept getting along with non working gauge needles and even a blank dash screen!
Upon my test start up all was normal!
I will try too report back in a week or so with a final analysis.
Both parts combined and delievered cost less than $90 by the way.
Ron
Old Nov 21, 2024 | 02:29 PM
Dr.Ron's Avatar
C7 Z06
UPDATE:
Ron
1st drive last night in the rain. So far 100% normal. The car should be driven more over the weekend.
Old Nov 21, 2024 | 02:47 PM
trigital's Avatar
W213 All-terrain
But....if CAN distributor had water marks, you should know that if you didn't solve the water ingress, the fact that the distributor is new ... does not mean that will be OK from tomorrow.
Old Nov 21, 2024 | 02:58 PM
Dr.Ron's Avatar
C7 Z06
Yes, but i did not notice any water stains or any signs of any prior water.
Old Nov 25, 2024 | 12:59 AM
Dr.Ron's Avatar
C7 Z06
It's now been 5 drives and the issue has not returned. I'm calling this fixed... until it's not again. Fingers crossed.
Ron
