GLa45 tire specs
GLa45 tire specs
His guys. What is the stock tire size for the 19s on the GLA 45? Also, anyone here running 20s and switch to 19s. I like thicker and wider tires one reason why I like to go 19s. Appreciate all comments.
sjp3003 (04-27-2023)
amgsin (04-02-2020)
Its not a wrong way to go there that. I have 50's on my MS6, and it was a squeeze cuz I went a centimeter wide, On a lifted SUV, you can run what you want without losing sleep over rubz
Do this one thing, and you'll avoid any objective issues.
go to tirerack, and lookup the "revolutions per mile" value for the OEM tires.
and just stay close to that value.
200/50-20
thats a tire spec, yeah?
so,.. 200= MM width of the tread area
the 50 value expresses the radial distance from the rim to the tread. its expressed as a ratio of the measured width.
the 20 is of course the rim diameter
So, in our case above, the tire forms a band of rubber 100MM thick.
the R/M value is simply an expression of circumfrence.
that taller sidewall will give you compliance and a nicer ride feel.
now, grip is coming from contact patch width, so more is better, yeah?
but, wider, at the same aspect ratio, is a lager diameter....... speedo is reading low, fitment in the well gets tougher, (and I am unsure to what degree the TC, DSC, etc systems may or may not get compromised)
so, from stock. you want comfort, fine, but that first number gets smaller
your choice to make now, but a solid reccomendation is printed on the doorsill
GLA45 tire specs
The GLA45S's come standard with 8-1/2" wide wheels fitted with 255/40 x 20 tyres. There is an option to go to 21" wheels.
Now, onto standard 8-1/2" rims you can get away with fitting a 275/35 x 20 tyre if you choose to do so. Though the specifications are for a 275 tyre the rims should be 9" wide.
Hope that helped.
Cheers,
Mark
Hope that helped.
Cheers,
Mark
I was just looking at my wheels on my '16 GLA 45 The Stock black Borbet 20 inch rims are 8Jx20 ET43.5 so not all came with an 8.5" this site does list a different option rim tho, with a smaller offset.
BTW, my stock tire was 235/40ZR20- there's not a lot of brands making tires for that size so I went with a 255/35ZR20
This is an amazing page for figuring out options.. So many good deals on different sizes that will fit well..
Tire rack has some Great deals on different options that will fit our rims well..
RebelC63S (03-27-2022)
