Dynamic select knob problem
I have a question because there is a problem with the drive mode change switch while driving the vehicle.
Switch Drive Mode When you turn the jog dial, sometimes it works well, but when you look at it when it doesn't switch, the lights on the jog dial are flashing as in the image. If you attempt to switch mode when the LED flashes and turns off, the mode will not change. I wonder why this problem is happening. Is the mode switching jog dial a problem? Or is the ECU responsible for switching to drive mode a problem.. I'm so curious. Please give us a reply.
video link:
https://twitter.com/i/web/status/1662481365307396097
