AC NOT working during EXTREMELY HOT WEATHER - 105+F degrees outside
AC NOT working during EXTREMELY HOT WEATHER - 105+F degrees outside. Seems to happen very often.
After the outside temperature cools down a bit to like 90's F degrees, then the AC is working.
Had it checked out at the MB dealership and they said it's NORMAL!!!
Also, not sure of the controls on your car but if it has a max button I would use this. This puts the AC in the recycle mode. This should eventually get the inside temp down quicker.
keep us posted.
Recirculation and set the AC temperature to lowest temperature MAX, and etc. A couple of weeks ago it was 105+ F and the AC was just blowing hot air from the get go. Then we were on the freeway going 70 mph for a good 45 minutes and the AC was just blowing HOT AIR. I MEAN IT WAS HOT IN THE CAR!! Went on for another half an hour..... Highway cruising....same HOT AIR THE ENTIRE JOURNEY. Gave up and arrived at destination where we had our other vehicles...... Lexus RX450h or LX570. OUT of curiosity we drove both in the hot weather.....both the RX450h and the LX570 both cooled down the interior in a jiffy.....less than 10 minutes I had to adjust the temperature from lowest/MAX to 70 F bc it was already getting TOO COLD!!! WE HAD NEVER EVER HAD ANY AC problems with ANY OF THE LEXUS WE HAD. One we had several years ago was a prior gen LX470 since new and sold it with 280K+ miles on the ODO WITHOUT ANY ISSUES, NONE WHATSOEVER. Not too sure about this GLB250????
The entire trip my wife kept saying, SEE, I TOLD YOU SHOULD HAVE GOTTEN ANOTHER LEXUS AND NOT THIS POS!!! Oh well, too late now. LOL
The LX got lots more interior volume to cool down PLUS a lot more GLASS areas VS the MB GLB250.
IDK, maybe there is a design flaw with the GLB250?
SO after getting back from the MB DEALER and was told all was normal...... We had not had any more issues with the AC, but it has not been that hot since.... We will keep an eye out for the AC and report back.....
keep us posted.
So, the procedure was to set the a/c on the outside air setting, not recirculate. All the interior surfaces and the air inside are 130 deg plus. Open all the windows and drive for a few minutes. That replaces the 130 air with 95 air and helps cool down the dashboard through which all the air is coming. Then roll up the windows but don't use recirculate. The a/c would catch up and all would be ok. Recirculate at the beginning just keeps 130 deg air going around in circles. In fact after that I hardly ever used recirculate. That had an added benefit of preventing mold build up in the system. We're still in Hou and own a '14 ML350 and a '14 GL450. I still do the window opening routine if the car has been sitting out.
You don't say if you still have the problem coming out of the garage or when the car is cool to begin with. Go to an auto parts store and get an a/c vent thermometer (pictures). Put it in one of the center vents. Don't try the above until you get readings when the circumstances are as you first described. Then park the car in the sun for awhile and let the interior heat up. Try the above and see what readings you now get. I got 41 deg at the center vent once I started doing the above. BTW the temp in my garage was 82 according to the vent thermometer. Good luck,
This is the fourth MB we've had. We still got the GLA which the AC works fine.
I still think that the AC unit in the GLB is not up to snuff bc they used a smaller capacity AC unit to cut costs. Therefore the AC can not keep up when it's EXTREMELY HOT OUTSIDE.
We had been driving for a little over an hour and the AC in the GLB was still blowing HOT air? We tried rolling all windows down and switch the vent to outside then recirculating air. NOTHING but hot air. We even switched to SPORT mode to COMFORT mode...... Still HOT AIR.
Maybe the MB DEALER made some adjustments to the AC but still told us all normal to "preserve" the GLB reputation? IDK. But now the AC seems fine. But it had not gotten that hot again yet. My wife and kids now INSISTS on taking the Lexus LX570 or the RX450h for any trip over 15 minutes bc she does not want to be riding in a HOT car again. I don't blame them.
Will keep you all posted on the AC on the GLB.
I will keep trying.....
Update after three days of temperatures displayed over 115 degrees on dash. All three days I used my sun visor from Mercedes and the ac worked fine. So my theory is that some type of electronic in the dashboard is affected by the heat from windshield even though I have ceramic tint installed. I see other post about adding Freon would not recommended the system could lose pressure or become overcharged. Take you car to get professional inspected and repaired. Hope this helps.
My wife didn't have time to get to the MB dealership in time before they closed. Of course after she got home the AC is working again.
Both times when the AC failed the ambient temperature is over 105 F. AND while the GLB is moving at highway speeds the AC was just blowing HOT AIR. After the Highway driving arriving at the house while idling, the AC decided to work!!!
I ordered the AC thermometer on AMAZON and will videotape the next time the AC fails again to show the MB Dealership if they tell me again "All normal"!!!
I will check it out and report back.
It does sound more to me like the compressor isn't engaging though. Wondering if you cycle on and off many times it eventually comes on.
A couple of times when we FIRST started the GLB and heading out from home the AC is not working and blowing HOT air.... We usually have time restraints to get to where we are going and NOT have the LUXURY of just going to our local (selling) MB dealer and hang around for half an hour to an hour ...... We were just too spoiled by our many Lexi vehicles where all were trouble free 😂
We will have to video record with an AC thermometer to document that the AC is not working as per another member's suggestion.
Will keep you all posted.
There is NO way this is normal.
Will keep you posted.
The June 16th entry is for the A/C and has a document the dealer can use to fix it.
I'm surprised the MB dealer did not know this???
