More issues with 2021 GLB35
Found Fault Code P04567A for a very fine leak in the evaporative emissions system. Performed leak test and found the vehicle failed the leak test. Found LI47.30-P-072421 and followed the procedure and removed the purge valve and tapped it on a while cloth and found chunks of charcoal present. As per the LI, removed and installed the fuel tank and removed and replaced the active charcoal canister and removed and replaced the purge valve and blew out the evaporative emissions line. Retested the vehicle now passes the leak test.
Some comments:
"Performance brakes squeak because of the aggressive compounds on the brake pads"
"All AMG breaks squeak!!… My C43 started around 1k kilometres in fact if you check the car manual it says it’s normal due to high performance breaks configuration. "
"I had an A35 AMG sedan for a couple of weeks as a loaner and the brakes on it squeaked every time I backed it out of my garage in the morning. "
Is this true? I've had Macan GTS, Audi SQ5 and their brakes didn't squeak like my new MB AMG..
Some comments:
As for Porsche brakes, my 911 had the same issue. the Cayenne was very quite. I believe anytime you get into these "higher performance brakes" they all share the same noise issue.
Hope this helps!
Some comments:
Hope this helps!
