viewing TPMS
https://youtu.be/EWuqkYVCJi0?t=189
I do have Premium 1, 19” wheels, and 3rd row seats, but there is no mention of an upgraded TPMS.
Even if the active tire pressure is not present on some GLBs, the passive system is good. We had it on a non-Mercedes. It compared the rotation of the 4 tires to the speed and if there was a difference in one, it would send a “Check XX Tire” message to the instrument display well before the tire was completely flat.
TPMS whether direct or indirect only alerts of low pressure once a pressure loss of 20-25% has occurred. That can be quite a loss. With 30 psi normal pressure for example, that's at least a 6 psi loss. So an advantage of seeing the actual pressures is to detect a potential leak before the system alerts. I personally use it as a piece of mind when I first drive off and the tires are cold to check if the pressures look normal, and while driving I can see if the pressures are as expected, so that if I drive over something and start seeing a loss in one of the tires relative to the others, I know right away that something is off. But generally, I'm actually more interested in the tire temperatures. Since I drive a powerful RWD AMG, seeing the tire temperatures lets me gauge the grip of the rear tires, so I know when I can get on it once they are up to temperature, or when I have to be careful while they are cold. So the advantages vary I suppose. Most people like to see the pressures as an early detection mechanism before the actual alert comes up and it may be too late. Neither system really absolves from regularly checking the pressures using a tire gauge and visually inspecting the tires for damage and wear.
For me, I am curious to see what pressure settings my tires and if they are even instead of going around with a gauge manually. I guess I'll never know seeing as I have the indirect system on the GLB.
My MBUX said Run flat is active but when scrolling down to Service there is no Tyre options for me to click in like other GLB 35.
I think best way to know is to call your dealer to ask whether you have that option.
