Auxiliary battery
If you get the dash warning light that's the one to pay attention to. I've noticed you can't use the accessory mode very long without discharging the battery to a level where you get the warning. I don't know if the vehicle has a lot of parasitic draw or not. It seems like it needs to be run more often than my other vehicles to keep the battery charged. I'm retired so it doesn't get started every day.
My 2020 Audi Q3 can sit for numerous days and not have an issue. Battery is always up and the start/stop function works right at startup. The MB start/stop may or may not work right away. Seems to need a fully charged battery, or close to it to work. I know there a lot of parameters to make S/S function on any vehicle.
I still suspect a failing battery. I'm not sure if they load tested it or not. Just seems that it is discharging quicker than normal when the car is sitting. Typical MB, don't know. Maybe the GLB needs to be run more often.
Guess I'll have to break out the VOM and monitor the battery voltage over a period of time.
On GLB250 you can go into vehicle setting and see full battery information, however on GLB35 it is replaced by something else.
