GLB Class (X247) Produced 2020 to Present
Paddle shifters
Old Jul 21, 2022 | 04:57 PM
Lindagail's Avatar
GLB35 AMG 2021
Paddle shifters
Who uses their manual shifting regularly? I’ve only tried paddle shifters once or twice on my husband’s Miata. I’m much more comfy with a 4 in the floor.
Old Jul 21, 2022 | 06:35 PM
decorily's Avatar
GLC 300d 4matic
[QUOTE=Lindagail;8602314 I’m much more comfy with a 4 in the floor.[/QUOTE]
You and The Beach Boys! !
Old Jul 21, 2022 | 08:26 PM
Lindagail's Avatar
GLB35 AMG 2021
They rocked!
Old Jul 21, 2022 | 10:53 PM
PColasanto's Avatar
E350 Convertible
I use mine pretty regularly on my corvette C8 because it goes back into automatic automatically. My E350 convertible stays in manual once you use either paddle, so I don’t use that often because I don’t want to do whole trips in manual and it’s annoying to push the button on the center console every time. I haven’t checked how the GLB35 does it because it’s still in the break in period, but probably will be the same answer. If I can play around with the shifters on occasion without having to force it back to automatic I probably will, but if not, I probably won’t use them frequently.
Old Jul 22, 2022 | 12:27 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I have had paddle shifters in 2 of my Benzes. Only used them once or twice in the first one to see what they did. I would nominate these as a delete option. Use ‘em if you like ‘em. Paddles don’t give the kind of control that a manual does. These transmissions are also quite well matched to their engines. My daughter and I are completely comfortable with 3-4-5-6 manuals regardless of location, but no one else in the family is. So there’s really nothing to gain for us, in my opinion.
Old Jul 22, 2022 | 01:23 AM
superswiss's Avatar
2019 C63CS
In my '19 C63 and other performance cars all the time. Pretty much exclusively drive in manual mode on the highway and for any spirited driving. Used to drive manual transmissions for 20 years. Automatic transmissions as good as they are these days still can't read my mind and know what I'm going to do next or see the road ahead. I don't use them in normal cars, though. For the most part they are laggy and unsatisfying. I just came back from a month in Europe where I was driving a new A6 rental for 4000 kms. Despite having a dual clutch transmission, it was like grandma shifting gears, totally numb, so I didn't bother. Just put it in S to get a better response, but left it up to its own devices. Paddles are satisfying and fun if the transmission is crisp, responsive and shifts on cue and uses a clutch instead of a torque converter. Otherwise it's more like a numb video game. First day back in my C63 I was ripping through the gears in manual mode again. It's the only way to get the most out of the car, either short shifting or winding out the gears as needed.
Old Jul 22, 2022 | 05:13 PM
skullbox15's Avatar
2014 C63
When I accidently hit one on the GLB250 I hear a whine that sounds like a mosquito coming from the engine. I doesn't do anything for the driving experience. I don't even know why they have them. It's like adding paddle shifters to a lawn mower. Like Superswiss said, on a C63... different story. I love downshift and hearing that roar of the M156. The GLB... not so much.
Old Jul 22, 2022 | 07:04 PM
wireman218's Avatar
2022 GLC 300 4 MATIC
10-4 I really don't see a use for them in these relative low HP cars. My 2020 Audi Q3 has them also. Both have about the same HP.
Used them a few times when going down steep hills rather than the brakes.
Old Aug 4, 2022 | 04:10 PM
Extremeengineer's Avatar
2021 GLB250
This surprises me. I have driven a lot of cars with paddles, and generally you either hold the + paddle for a couple seconds, or hold both paddles simultaneously to transition back to drive, but you are saying you can't do either on a MB? I used to use the paddles on my Macan GTS when I wanted to hold a gear, but on my 911 I found the transmission so intuitive that it would hold gears like it was in my head, was eerie honestly. Just surprised MB would not have a simple way of getting out of M as above.
Old Aug 4, 2022 | 04:24 PM
superswiss's Avatar
2019 C63CS
Yeah that doesn't sound right. If you just use the paddles in an MB and most other cars it activates temporary manual mode which automatically reverts back to automatic mode after a few seconds. Except in certain situations it extends the time it stays in manual mode. For example if you keep accelerating and slowing down, if there is significant lateral acceleration or if you are driving up or down a steep enough incline. Then it stays in manual and holds the gears until things level out and the car drives again at a steady pace, then it automatically reverts back a few seconds later. At any time you can just flick the gear selector to D again to immediately go back to automatic mode. I think pressing and holding the upshift paddle works, too.
Most regular MBs don't have a permanent manual mode. Some like the C class allow to permanently activate manual mode in the Individual DYNAMIC SELECT profile so then the transmission stays in manual mode as long as I* is active. The SUVs typically have permanent manual mode for towing that can be activated via a button in the center console. To get back to automatic mode you have to press the button again. AMGs have the manual mode button in the center console and now also on the steering wheel with the new AMG Drive Unit and in addition manual mode can also be configured in the Individual profile, which is how I have my C63 set up. So whenever I activate I*, I'm immediately in manual mode.
Old Aug 4, 2022 | 04:33 PM
Odd Piggy's Avatar
Try this:
Most Mercedes Benzes will go back to normal driving mode (D) if the UPSHIFT (+) paddle is held for about 5 seconds.
Old Aug 17, 2022 | 12:34 AM
PColasanto's Avatar
E350 Convertible
Thanks for that, and to the others. Maybe I just wasn’t waiting long enough, but I got in the habit of hitting the mode selector quickly after using the paddle shifters. I’ll try letting it go longer or the +paddle trick.
I think when I did it I would downshift through a turn or something, but it would stay in the low gear when I accelerated coming out of it. In my C8 it will smoothly transition back into automatic, but the Mercedes’ hangs longer than I thought was appropriate, and the indicator says “M”, so I thought it needed a human intervention to go back to auto.
Originally Posted by Odd Piggy
Try this:
Old Aug 17, 2022 | 06:25 PM
Odd Piggy's Avatar
I just tried the downshift into a turn. That might feel okay in my C250 because you can hit the turns really hard. But not so much in a GLB250 grocery and student hauler. It stayed in that gear until the stop sign. I put it back in D withe the + paddle.
Old Aug 18, 2022 | 12:49 PM
PColasanto's Avatar
E350 Convertible
Played around on my E350 and it does eventually go back to automatic, but takes way longer than feels appropriate. I could probably get used to it.
will have to do the same with the GLB35 and see what I think.
