GLB Class (X247) Produced 2020 to Present
Roof rail retrofit?
Old Mar 21, 2023 | 01:40 PM
Tomadam's Avatar
C350e
Roof rail retrofit?
My car is missing the roof rail! Can I retrofit it somehow? Genuine of aftermarket, I don’t care.
Old Mar 21, 2023 | 10:46 PM
ILoveNY's Avatar
GLC EQB GLS C300 convertible
will it affect insurance?
Old Mar 22, 2023 | 12:44 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Roof rails are available for purchase at online MBUSA parts. There are grommets and nuts in the drawing, so it looks like they may attach to predrilled holes. I would call an MB authorized body shop and ask. Then you can decide whether to install yourself or not.
Old Mar 22, 2023 | 07:05 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Below is the link to roof rails for 2021 GLB 250 with panoramic roof, from one of the online BM parts stores. Depending on the year and configuration of your car it could be different I guess, but you can certainly purchase MB OEM roof rails.
https://www.shopmbpartsnow.com/oem-p...bC1sNC1nYXM%3D
Old Mar 22, 2023 | 04:00 PM
https://www.ebay.com/itm/36417471836...Bk9SR8q-ta7hYQ
Old Mar 22, 2023 | 05:01 PM
MnewB22's Avatar
GLB 35 AMG
The roof rails mount into slots in the black roof channels. Are there slot covers to mount rails on your roof (photo)?
Old Mar 23, 2023 | 02:34 AM
Tomadam's Avatar
C350e
Thanks all! I’ll call Mercedes about the mounting points.
Old Mar 23, 2023 | 11:46 AM
skullbox15's Avatar
2014 C63
FYI, I had an issue mounting the MB roof racks to my C-class. For some reason one of the bolts for the rear part of the rack wouldn't screw down correctly. I initially thought I didn't have them aligned correctly. I ended up figuring out the bolt hole wasn't treaded all the way from the factory. I ended up taking the screw to the hardware to figure out it's thread pattern. I ended up buying a metric tap set. Re-tapping the hole and then it worked just fine.
