GLB Class (X247) Produced 2020 to Present
DashCam - 2021 GLB 250 - NTG6 Connect Mid - Possible
Old Sep 17, 2023 | 09:19 PM
embeleco's Avatar
GLB250
Hi. My car came with the Connect 20 Mid and not High.. So not augmented reality for me and of course no built-in dash cam. I heard about a FitCamX dash cam option - https://fitcamx.com/products/fitcamx...glb-amg-glb-35. But not clear if it needs the Connect 20 High for the required wiring or if the Connect 20 Mid comes with the required hardness as well.
Have any of you out there used the FitCamX option with the Connect 20 Mid (NTG6)?
Old Sep 18, 2023 | 10:45 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
The link is to the aftermarket dash cam. They typically come with adapter and plug into rain sensor plug. The cam is connected to your phone, where you need to install their app. Nothing to do with onboard control unit.
Old Sep 18, 2023 | 02:17 PM
embeleco's Avatar
GLB250
Thanks Vlad. I was referring to the onboard control unit as to where it was going to be connected.. I did not realize that it just connects to the rain sensor plug. Thanks for the clarification... I will go that route then.
Old Sep 18, 2023 | 02:21 PM
When ordering, make sure you get one that plug and play, using rain sensor. Older versions had a wire that had to be run into fuse box.
