GLB Class (X247) Produced 2020 to Present
SEL with code P219D
Old Nov 19, 2023 | 04:44 PM
theskippertooo's Avatar
GLB 250
SEL with code P219D
I recently notice that the engine light comes on intermittently on my 2020 GLB 25. I was able to put my reader on it and it came up with 219D as a code. Next time I started it up, the light was gone again. This has been happening for a couple weeks. Anyone familiar with this? Ive done some research on the code and Im wondering if I take into the dealer if it would be covered under warranty since I haven't exceeded the warranty miles yet. Im also wondering if they will give me the run around since the light isnt always on and they cant read the code. Any thoughts/
Old Nov 19, 2023 | 05:38 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
The error code should be normally stored in the car. Also it helps to take a photo when it happens. MB service should diagnose and fix it under warranty. So it looks like it is the same error as P219C, on different cylinders.
P219C: Cylinder #1 Imbalance Error : https://dot.report/dtc/P219C
P219D: Cylinder #2 Imbalance Error: https://dot.report/dtc/P219D
A code P219D should be categorized as severe and rectified as quickly as possible:
https://www.obd-codes.com/p219d
Also you should check the post on warranty extension on GLB:
https://mbworld.org/forums/glb-class...nder-head.html
Old Nov 19, 2023 | 05:52 PM
GLB 250
Yes, I did get a photo of the SEL light when it was on and I took a pic of my OBD scanner error code as well. Thanks for the heads up!
Old Nov 19, 2023 | 09:29 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Demand a loaner. It’s a 3 day job if they have the part and can dedicate a tech to your car only. Typically they’ll keep the car for 7-10 calendar days.
Old Nov 19, 2023 | 09:47 PM
GLB 250
My dealer has always been excellent when it comes to loaners so Im hoping itbwont be an issue. The question is will they have the parts or will it be a month for them to be shipped over. Thanks for all the advice.
