GLB Class (X247) Produced 2020 to Present
2023 GLB Dashcam Options and Considerations in US
Old Mar 12, 2024 | 05:55 PM
louiedogg16's Avatar
2023 GLB 4Matic
I’m looking at installing a dashcam. I have a 2023 GLB w/ parking, driver assistance and multimedia packages.
Looking online, I see mixed feedback on whether I can use the factory installed augmented navigation camera for dashcam. Some say you can pay a $200 lifetime fee in Mercedes Me app, some say you can’t do it in the US.
I called Mercedes Me support, Mercedes Customer Support and the local shop - all basically said wtf are you talking about.
So, assuming using that camera is not an option in the US…
I see this option:
https://fitcamx.com/products/fitcamx-dash-cam-for-mercedes-benz-glb-amg-glb-35?variant=41745288921260
However, it seems like the aftermarket trim piece doesn’t accommodate the augmented navigation camera….
The OEM accessory camera (part 2139055310) is only front, no rear in US (per parts counter)
So is the only option a peel and stick front/rear option? Fine if so, just totally confused about what is and isn’t possible.
Old Jun 3, 2024 | 10:10 PM
krafourzee's Avatar
2021 GLB
I also went through this and concluded that in the US you cannot pay the 200 and use the augmented camera. I even went as far as buying a USB-C SSD and tried to plug it in to activate that option. (Also didn't work even though I read somewhere that it could) I'll also add that based on the low quality and poor fps I don't think I'd want it as a dashcam anyway but I would've probably paid 200 to not have to install a dashcam in the car for awhile.
I ended up going with a Thinkware U3000 2CH. There is a kit version with an OBD port connection to be able to keep running in parking mode when the car is off and automatically turn off at certain battery voltages. It uses Radar to do that, so it can run longer before draining the battery to the safety level which is nice as well.
I ran the cable to the back through the car's roof and the installation wasn't too bad, so far I like it. Definitely not the cheapest option, but I have the U1000 in another car and that has been solid as well so I stuck with Thinkware.
Old Jun 4, 2024 | 01:52 PM
kgzero's Avatar
2022 GLB250
I bought a Viofo A229 Plus, 2 channel. Its 1440P front and rear. I routed the wires down the passenger side pillar then routed the wire for the rear cameras down the door sills, shoved it under the rears seats and up the rear panel to the roof liner. I then routed it through the rubber...for a lack of a better word, rubber conduit (where the wires for the rear brake light go from the headliner to the rear window panel) and shoved the usb connector through the rear window panel (at the top) to connect to the rear camera.
​​​​​​Works well, the camera cost me $180 from Amazon, plus $17 for the lens polarizer. You'll also need a high endurance microSD card.I gor a 128GB card, but i should have gotten a higher capacity one.
Old Jun 7, 2024 | 12:14 PM
2023 GLB 4Matic
I got the FitcamX, I have a VIOFO for our Mach E.
Overall, I think my experience is consistent with common knowledge… FitcamX is fine as a camera but provided an OEM type look. If you want the best camera, get something else.
I opted not to go off a fuse for always on. Cable to rear was fished above camera, along headliner to passenger side. I ran it along the top to the rear and fished through the rubber grommet.
The only annoying area is the pillar between front and rear passenger side. I couldn’t get the cable to be hidden between the top pillar trim and the headliner, so it’s not noticeable but if you look at it you will see the cable. Kudos to MB on trim fit tolerances I suppose.
Old Jun 8, 2024 | 03:16 AM
EQBFan's Avatar
EQB 300
That's the reason why I decided against routing the cable to the back and chose to use the rear camera as an 'internal' cabin camera instead. Just eliminates the headache of routing the cable to the back of the car. Instead, I got another 4k dashcam, and used the rear 12V charging point to power it up. Thats just a 2 minute job - you only need to pull back on the rubber beading and there is enough space between the body panel and the trim cover for the cable to be routed.
I have a Viofo 229 Pro 3 channel camera in my other car, which is a way better camera but and the rear camera cable was a pain to route.
If you are using a FitcamX, I would recommend checking your video footage for coverage. Fitcams are notorious for overheating and stop saving footage after a while. My first one had this issue - I wrote to them and they were happy to send me a replacement.
Old Sep 25, 2024 | 05:18 PM
takamatsu's Avatar
GLB35
Hi
I've just installed FitcamX on my 2024 GLB35 and it is so far pretty good. It can record both front & rear video in 4K resolution as well as sounds. When you connect BAT+(always ON) from the fuse box instead of utilizing the rain sensor connector(default), the cam starts recording with an inpact even when the engine is off.
GLB35 in SF
Old Sep 25, 2024 | 07:29 PM
takamatsu's Avatar
GLB35
I also struggled with cables of FitcamX and ended up asking a body shop to tuck them. They did nice and no cables are noticed at all. I did not see any heat issue so far on it but I had some issues on the rear camera recording. I asked FitcamX support and after installing the latest firmware, it's working fine.
