What’s your oil change interval for glb250
Over on the Subaru pages, there were mass concerns about using anything other than the proprietary trans fluid, even tho companies like Amsoil claim to compatible, the community highly advised against it as it could damage the CVT transmissions. (The CVT may be the bigger culprit.)
I mean, it is not a lot of brands to choose from.
The DCT in the GLB is sturdy and reliable. However, the wet clutches will wear quickly if the friction characteristics of the fluid have deteriorated. Change on schedule or earlier.
Xentry is not necessary ONLY IF the complete service procedure is available or known. Then a scanner with dedicated current MB software can be used. I farmed mine out because of this.
BTW - It would be great if you could document your fluid change and post it for other users.
Would everyone agree that the brake fluid must be changed out every 20k as well? Even cabin filters every 20K? Cabin filters are inexpensive enough, but the brake fluid job seems a bit extreme...or am I being ignorant? Any insight is appreciated!
A brake fluid flush should be inexpensive if you do it yourself. The most expensive part should be getting the proper fluid. Use a fluid transfer pump to presurize the fluid to about 10-15 psi, and then open the bleed screws in sequence for each wheel, usually starting with the furthest from the reservoir. There are plenty of YouTube videos on how to do it.
(Trying to upload pics, but not working on the MBWorld website today.)
I'll definitely stick to the scheduled maintenance at the very least. My wife will be doing most the driving and will keep it in comfort mode, so I hope it doesn't see more than typical wear.
I do plan on making a thread for the 35 and using it as a maintenance log of sorts to document it as best I can for when the time arises.
OEM is the only way!...in most cases
I'm somewhat well versed when it comes to changing out the brake fluid on certain cars, in a poor-man's way...I've done a few BBK's on past vehicles and I'm almost embarrassed to admit how many bottles of brake fluid I've gone through. May be time to invest in some proper tools!
As I get older, I'm more gauged to the idea of having proper tools, even though I may only use it a handful of times, ha.
