Spare tire
https://modernspare.com/product/2019...e-kit-options/
You can select GLB35 in tirerack and go with the cheaper option as it will be staying not used most of the time. Here is the official specs:
https://www.wheel-size.com/size/merc...lass-amg/2021/
I have 8.5Jx20 ET42 Mandrus Estate wheels (made for MB) for winters and they fit with no problem. I bought them from ebay and installed it at the local shop. I also have another set 8.5Jx19 ET42 for AS from same manufacturer with different brand name, and the wheels didn't clear the brakes. Luckily I had 10mm spacers at home as initially I bought them for the winters, so they installed the spacers with 19" AS's. Try to stay with ET49-53 range with the wheel.
Donut compact spare
Still have not been able to find a perfect match for my 18" wheels yet. I am running 235/55 spec tires.
https://www.wheel-size.com/size/merc...lk-class/2015/
Only problem is tire age eg newest tire will be 9-10 years old unless you find a newly manufactured one...
And yes, there is the age. I was hoping to get a relatively unused one on ebay with the hope that I may never have to use it. I am fairly adept at plugging punctures - the spare would only be used in case of a sidewall cut.
The 17" spare from the GLK may work out for you. See this thread - folks have been able to mount it on the 2017 GLC which also used to ship with rim sizes between 17-20".
GLC Spare Wheel
