GLB Class (X247) Produced 2020 to Present
GLB 2021 intermittent squeaky sound when making a slow sharp right turn
Old Nov 22, 2024 | 10:05 PM
sammbux's Avatar
Hi all,
I am currently facing an issue with my GLB 2021 which makes an intermittent strange squeaky noise when performing a slow (below 7mph) sharp right turn.
I have taken it twice to the MB Dealership - the first time they weren’t able to reproduce the issue, however they were able the second time I brought the car in. Thus they decided to take it “into the workshop” on another day to test it again with the same engineer, but again weren’t able to reproduce it, stating I should take the vehicle back from them to see if it will happen again. Given this has been happening for many months now, I doubt this will solve anything. Before this incident, there was a recall to perform a steering update which they did, but interestingly enough not long after that update the issue surfaced.
Attaching a video to demonstrate the sound that occurs:- https://drive.google.com/file/d/14N1...w?usp=drivesdk
Has anyone faced this issue before, or might have an idea what is causing the sound?
Thank you!
Old Nov 23, 2024 | 12:08 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
It remotely sounds like a belt noise. Years ago I had a car that made winding sound when turning. Ended being one of the belts.
Old Jul 24, 2025 | 09:50 AM
Love2fish's Avatar
2013 SL550
Worth fixing?
I have the same problem, massage sort of works barely but then stops. Local independent MB shop wants $450 just to start diagnosing. I don’t mind paying to fix it if it’s a great feature, but if the massage is subtle or basically worthless then why bother? Can anyone provide their thoughts on how well the seat massager works?
Old Jul 24, 2025 | 12:21 PM
I don't believe that any trim of GLB has a massage feature. The only thing that glb seat does is moves it a bit to keep you awake.
Old Jul 24, 2025 | 02:07 PM
Sathinas's Avatar
S65
Aside from digging up dead threads, what does your seat have to do with a squeaking engine belt, again? Asking for a friend.
If you actually have massaging functions, then likely one or more of your seats' air lines or PSC pump are bad.
Old Jul 29, 2025 | 12:35 PM
Hfdt521's Avatar
@sammbux Any update if you got it fixed? Having same issue
Old Aug 10, 2025 | 12:56 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Sounds like a humming sound...maybe the steering fluid?
Old Aug 12, 2025 | 09:34 AM
Sathinas's Avatar
S65
Thank you!
This one's a no-brainer. Perform faster and sharper right turns.
You're welcome.
Old Aug 12, 2025 | 07:07 PM
W205C43PFL's Avatar
You're welcome.
