'24 GLB 250 - Check Engine
Incredible.
First dealer checked and said nothing recorded on ECU.
Second dealer checked and said nothing saved on ECU but it came up again today and then cleared later.
P.S. Sorry, I did not notice that your model was 2024. Supposedly MB uses new cylinder heads starting 2024 model year.
Maybe it really isn't popping any codes.
Silly me thinking that the issue of my CEL was due to my after market door puddle lights. It was a coincidence that the CEL went away after unplugging them.. couple days later it came back on. I took the car to the dealer and after connecting the XENTRY they found a code U061F11 (Communication with Exhaust Gas Temperature Sensor 1 has a malfunction. And code U061F08 (Communication with exhaust Gas temperature sensor 1 has a malfunction and there is a signal fault or the message is faulty.
They replaced the upstream exhaust temperature sensor along with a cable having issues (not sure which one). Cleared all DTCS and here we are... let see if the CEL comes back again. Anyways updating my post here in case it can help anyone out there with a similar issue.
