GLB Class (X247) Produced 2020 to Present
Uneven Brake Pad Wear
Old Dec 30, 2024 | 02:02 PM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
I just replaced my front brake pads and rotors and found that inner and outer pads did not wear evenly by a factor of 3. Inner pads were 3mm thick and outer ones were 9mm think. Rotors were worn out on inside wall as well. When i changed rear brakes and rotors last spring, the difference was there, but not to this degree.
I have never seen such a huge difference in brake pad wear. Is it common for MB?
Old Dec 30, 2024 | 10:46 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
That’s not common. I don’t usually check my inner pads until the outers are below 50%. My E Class had wear indicators on both inner and outer pads. My C Class didn’t but pads on all 4 wore perfectly event.
Thanks. I’ll have to change my routine on the GLB & the GLAs.
Uneven wear could be caused by the caliper slide surfaces getting rusty and it not moving smoothly or binding.
Old Dec 31, 2024 | 09:36 AM
Front passenger side inner pad has wear indicator. Rear pads do not have any.
Old Dec 31, 2024 | 09:42 AM
Slide pins were free moving and had no rust on them, however, not a lot of grease inside the rubber boots. The grease was pure white, never seen that color grease before. I typically use silicone grease.
Old Dec 31, 2024 | 01:02 PM
Odd Piggy's Avatar
GLB/GLA are definitely down at the bottom of the ladder. While it seems to be a fairly competent vehicle (70k+, 50k+, 25k on ours), I’m going to have to treat it more like our domestics.
I think the caliper grease is white lithium grease. I have a tube made by Lubriplate that I’ve used for years. I don’t think the type of grease is critical, but I have heard that different formulas should not be mixed.
