GLB Class (X247) Produced 2020 to Present
GLB 250 - Draft from driver's door
Old Nov 28, 2023 | 10:13 AM
MBenzdriver's Avatar
2023 GLB250
Hello everyone,
First post and new to this forum and page. Just took delivery of the '23 GLB 250 and experiencing a few major issues.
First major issue is the driver's door seems to have cold air seep into the vehicle. I started noticing it last week as the temperature dropped (30s and 40s) in New York. The heat works fine and I have it set to blowing air from both the front and bottom vents. However my entire left hip and leg feels cold when driving. Otherwise the rest of my body is warm and comfortable and the interior temperature does warm up to the set heat temperature.
The driver's door closes poorly, requiring to use more force to close it each time I exit the vehicle. This is a known issue I read here and I'm wondering if this is causing the cold air to seep through the bottom part of the door. I did have the dealer look at the door not closing well, prior to experiencing the draft from the door, and they told it's operating normal and I need to apply more pressure to close the vehicle door.
I would appreciate any insight to help me get this issue fixed. I have the car for less than one month.
Thank you,
Shawn
Old Nov 28, 2023 | 10:56 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
The door needs force to close is a typical issue with this model. In my opinion it gets more noticeable when only one door is open, and air has no room to escape. My driver door got better through use.
If you do not see any door misalignment issues or weather seals out of place, then you best bet is to go to dealer and have them replace door seals. If the door is misaligned than that could be a culprit for your door closing and weather seal issues.
Old Dec 6, 2023 | 04:31 AM
2023 GLB250
Thank you for that insight. Im scheduled a service appointment for today and I will share this with them. Any other suggestions to help me get it fixed?
Old Jan 6, 2024 | 11:44 PM
Redvelvetboots's Avatar
2023 Mercedes GLB
Holy cow I thought it was just me!! Same issue with my GLB. Drafty on the driver's side and lots of wind noise when highway driving. Almost as if the window is open. I do have to remind myself to really firmly close the driver's side door. I'm really regretting buying this car. I've only had it for three weeks.
Old Jan 13, 2024 | 11:28 PM
2023 GLB250
Unfortunately this is still an issue for me and I feel it when the temp in NY goes below 50. I'm scheduled to go back to my dealer (now 3rd time) to see if they cam fix this i@Vladimir Ivanov or anyone else have any other suggestions to share to help me get this fixed once and for all?
Old Jan 19, 2024 | 02:50 PM
2023 GLB250
After dropping off my car for now a 3rd time to address the draft issue from the driver's door along with a few other problems I'm experiencing, I was informed today they found no problem with draft air coming from the driver's door. It makes driving the car difficult especially when it is cold. Any suggestions on how I should address this?
Old Feb 2, 2024 | 04:27 PM
2023 GLB250
Were you able to resolve this issue? Please keep me posted b/c I still experience cold air from the driver seat, heating my left torso and leg.
Old Feb 21, 2024 | 02:23 PM
2023 GLB250
Hi @Redvelvetboots were you able to get your issue with the wind noise and drafty door fixed?
Old Jan 1, 2025 | 09:49 PM
GBL NAH's Avatar
Good Luck
I have a 2020and mine is loud driving on the highway. Sounds like the window is down. I have no faith in MV fixing anything. They have been horrible. Biggest regret.
