Runflats?
Found this on Aussie tire site, we have Pirelli, but comment re BRIDGESTONE is interesting, re thinner sidewalls !
Try this .... https://www.jaxtyres.com.au/tyres/ti...ended-markings And..
https://www.jaxtyres.com.au/tyres/run-flat
Cheers from Oz.
Cheers from Oz.
http://www.pirelli.com/tyres/en-gb/c...nology-runflat
Cheers from Oz....
Good description of RFT tech and Mercedes MOE developments.
http://www.caradvice.com.au/336921/c...run-flat-tyre/
Happy reading.
Cheers.
Happy reading.
Cheers.
Im glad Mercedes is using a standard wheel given having special wheels would just add to your issues if you needed a tire on a road trip.
Last edited by Teckno; Apr 12, 2016 at 08:34 AM. Reason: Duplication of my earlier post !
Tire centre (Jax) advised the tire was able to be repaired as the tire was never driven without pressure and due to the location of the nail, if it was elsewhere, could have been a different story.
In short $50 and 20 minutes was alot better than $470 for the replacement!
Where did you get a quote for MB MOE Pirelli for $470. That's about $300 discount on my quotes ?
Thanks again.
Would it be wise to switch out the run flats right after getting the car? Is there any market for very slightly used tires?
I'm planning some road trips in the new car, and I'd rather not deal with the problem of having a flat a couple hundred miles from a big city and having to be towed to a MB dealer just to get a new tire.
Thoughts on this?
TIA
Thoughts on this?
TIA
I've been driving on extended mobility tires since 1999. During that time have suffered two punctures. After making a visual check to ensure it was nothing more than a puncture, got back in the car and drove to the nearest tire shop where the tire was repaired.
