Distronics Plus Failure
Old Mar 23, 2016 | 10:33 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
After getting on the freeway attempted to engage Distronics Plus. It failed to engage, and instead, on the multifunction display, I observed the following message, "Radar sensors dirty."
It was snowing heavily and the roadway was extremely sloppy. Temperature was just above freezing.
I stopped at a gas station and inspected the sensors. Sure enough, they were completely covered by frozen precipitation. I cleaned them off and got back on the freeway. Distronic Plus operation normal.
By this time the weather had greatly improved and within several miles the roadway became dry. But I'm thinking if one is driving some distance in freezing or near freezing precip., repeated stops will be required to clean those sensors. Very inconvenient. In my case I had driven about six or seven miles on local streets to reach the freeway.
Old Mar 24, 2016 | 12:35 AM
index1489's Avatar
BMW
Surprised its not heated, prob will be in future models.
Old Mar 24, 2016 | 02:53 AM
cyber3d's Avatar
GLC 300
Check your manual. I belive I read somewhere that Distronic Plus should not be relied upon in such in climate weather.
Old Mar 24, 2016 | 09:11 PM
Veteran: Air Force
You are quite right. I must confess you are a more thorough reader than I. And so you are getting a thank you.
Dirty sensors are mentioned in at least three places in the Operator's Manual. In the section detailing Distronic Plus operation. In the section concerning Parktronic. And lastly in the Care section which in turn refers you to the Digital Operator's Manual.
In my defense I equate our Operator's Manual about as easy to read as a Tolstoy novel. It would be much better if tech. pubs. could keep it away from the legal department.
Further, I'm a lousy driver with Distronic Plus and even more so without. So I think I'm going to assign the position of "sensor cleaner" to my spouse. Am thinking a cleaning interval of every 25/30 miles should suffice.
Old Mar 25, 2016 | 01:34 AM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Hi, manual in our Mazda3 stated not to use screen glass coatings over the area where the radar and cameras operate, as the coating might confuse or interfere with safe operation of sensors. I presume it's like rain or anti glare, streak coatings for front windscreens.
Cheers
Old Mar 25, 2016 | 01:41 AM
cyber3d's Avatar
GLC 300
Cheers
BTW, one should not use products like Rain-X (screen glass coatings) on cars that have rain-sensing windshield sensors. It will confuse the sensors.
