I discovered that...
I just discovered last night that the Intelligent LEDs turn on additional wide angle beam as you approach a roundabout in conjunction with Sat. Nav.
There appears to be 2 different styles of star on the front. One has a 'flush' finish with the star on a shiny backing while the other has the star with a recessed mesh behind. I'm presuming the 'flush' one has some radar apparatus fitted.
I'm still trying to figure out how the park assist works when pulling up to a parallel space?
I know I should read the manual but any pointers?
Seriously, can't believe how many folks there are out there on a Sunday afternoon that don't know this
The hardest part to figure out was not, IMO, explained well in the manual. It's intuitive though. The car has to measure the space. This means there must be two cars, one in front of and one behind the space. The measurements seem to be taken from the rear of our Mercedes. Thus you need to signal your attention to park before the rear of your car passes the front of the car behind the space. And you need to pull up far enough so that the rear of your car passes the rear of the car in front of the space.
In my GL, these are necessary. But really with the 360 camera it's just easier to do it myself!
From page 305 of the Owner's Manual:
* Vehicles without memory function: if necessary, move the driver's or front-passenger seat forward.
* Vehicles with memory function: when one or both parts of the rear seat backrest are folded forward, the respective front seat moves forward slightly, when necessary, in order to avoid contact.
One additional interesting feature: The next bullet on that page shows that you can place the seat belt tab in a pre-cut hole, so they it won't rattle or bang around.
Last edited by JM-GLC; May 14, 2016 at 09:24 PM. Reason: to include supporting documentation - reference from manual
See page 312 of the Owner's Manual for details/pictures.
Found out Sunday that if you pull the cruise control arm towards you ("RESUME"), it will set the cruise. Had only thought that you had to push down for set/decrease.
I bought a spare from modernspare.com and it fits neatly under in back. The improvement in ride with non RFT is amazing. I can fit spare and tools and there as well as some other things (owners manual, umbrella, snowbrush, etc)
