Wheel Vibration when hitting small bumps in road
#201
- I think it’s the suspension - MB is trying to be sporty like BMW, with stiff suspension. When I’m driving the GLC300 and go over a bump or over a ramp into a parking lot, the front takes a huge hit and it sound awful. Everything on the glc300 is cheaply made - windshield, wipers etc
Benzgurl#1 (10-12-2020)
#203
Before I purchased my GLC I drove all three tire sizes and had each car for at least 2 days. Spending 60K is an important investment.
I also read everything I could find, including this MT article when it was rated best SUV for 2017. Note the mention of the “ jittery” handling as well as the notes on what the design engineers accomplished with mostly existing materials.
https://www.motortrend.com/news/merc...v-of-the-year/
I have over 20K now, very even tread wear on the original tires which I inflate to 35 cold, and, in spite of experiencing the same sensation from the suspension that some drivers complain about, I’m still satisfied because I rigorously tested this vehicle before buying.
This is my third benz in 20 years. Each of them have had some peculiar individual issues that took some getting used to. Overall, MB still makes the best.
#204
Thanks for the response. It will definitely take some getting use to. I traded in a Lexus RX350 and the ride quality is night and day. I have 32 in The fronts and 42 in the rear. I will try 35 and see if, this helps. We have harsh winters here so, I’m very leery of spin outs. I will call the dealership tomorrow. There’s no way this is considered normal.
#205
#207
#208
After experiencing this problem for the first year of ownership, lowering the tire pressures, and getting no solutions from the dealer, the crap Pirellis run flats that came standard wore out in less than 20,000 miles. Decide to refit with standard Michelins (not run flats).
PROBLEM SOLVED!
What happens when we get a flat, you may ask. That's what road service insurance is for. At least I (hopefully) won't be having to replace a very expensive run flat tire (as you will with the Pirellis which are "not repairable").
PROBLEM SOLVED!
#210
bottoming up is a characteristic of the car. I drove test 2 new 2020 GLC coupe and found the same issue. The only issue that can be avoided or minimised is the sound from wheels and the pits handling. Mine is 2020 GLC coupe and I changed my Michelin non run flat to continental sports contact R20. So far drive nice but same with regards to huge bottoming up on bumps, u feel the dashboard will fall and your tethers a huge hit.
#211
I test drove a brand new one with those continentals. It did seem to ride better however, someone else posted that the Goodyear
weatherready had a better review for snow and rain on tire rack. How long have you used these continentals and how have they performed?
#212
mine is all weather since I live in riyadh saudi Arabia. I have a feeling that it won't last too much and I would be lucky if it lasts 4 years or my usual 25 to 25k mileage in 4 years. I honestly lost love to the car the moment I drove and saw the primitive functionalities it have compared to the price I paid. Still contemplating selling it and getting a range rover velar or a BMW X5 OR 6
#213
I finally purchased a set of non run-flat tires a few days ago. Problem solved.
I chose Goodyear WeatherReadys, 235-55-19. Handling remains tight but the ride is now properly Mercedes-like, with all of the annoying impact harshness and body vibration gone. I picked up a compact air pump and Slime for $22 at Pep Boys, and of course I have 3+ years of roadside assistance remaining. I'll buy a spare and a jack if I decide to keep the car past the 4 year mark, .
#214
My brand new 2022 GLC has this issue, the steering vibrates for several seconds after hitting a bump at highway speed. Really it will vibrate until you apply pressure to the steering and break the resonance The software update did not fix it, and the dealer is still investigating. I got a courtesy car, also a 2022 GLC, and it has the same issue! Are any other 2022 owners experiencing this?
MrGizmo0 (04-03-2023)
#215
Exactly the same for me here. With 20" wheels : though the car drives just fine otherwise, it vibrates for several seconds after hitting a bump at highway speed. On a 2022 GLC too. I must also tell you that it is my 2nd GLC and the previous one (with 19" wheels in run flat, and air suspension) never dit this.
Really strange.
Really strange.
#216
Just a quick note. I have a 2019 GLC 300 so I monitor this forum. What I will tell you is I have Goodyear Assurance WeatherReady tires on my 2015 Kia Sedona and after 80K miles, still have 6/32" tread. Pretty impressive! Handle pretty well in the snow also for a non-winter dedicated tire.
#217
Got my 2022 back from the dealership. There is a software fix, though not the same one as mentioned earlier in this thread. Seems totally fixed now. Mercedes is aware of the issue, just bring it in if you experience this.
glc300_2022 (01-27-2022)
#218
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
We are RHD, so maybe we will miss out on this ??
#219
I believe the code is 540991. Just make sure they open a PTSS case with corporate. I had them try the xentry update posted previously here and it did not work. It was only after they opened the PTSS case that the engineers in Germany provided the new update.
The following 2 users liked this post by koziarbr:
glc300_2022 (01-27-2022),
Teckno (01-19-2022)
#221
I did quick search for this code and not much were found, just basic flash for this code
http://www.mybclasselectricdrive.com...opic.php?t=256
540991 PROGRAM AND CODE CONTROL UNIT
Potentially they just updated the ECU with latest firmware but how this can fix vibration?
#222
Running into the same issue with my 2022 GLC 300 since the day of purchase. Dealer awaiting further instructions from Germany.
#223
Can you please post the screen of paper work from dealer?
#224
Does the SW upgrade work for 2016 GLE250D?
My question - does LI46.35-P-062791 cover a 2016 GLE250D? I am hoping the answer is YES. The interior is great and the ride is smooth on good roads, but the sway and "kick" when hitting potholes and manhole covers makes for an unnerving ride. I have had 2 fully loaded Acura MDXs in the past and loved them, and was expecting my MB experience to be ever better. So far, it has not been good.
Any guidance greatly appreciated! Thanks!
#225
Hi! Just purchased a 2016 GLE 250D with 34k miles on in. I have been experiencing the "control" issues when hitting a manhole cover or pothole when going above 40mph (feels like the back end is kicking out / car is going a bit sideways). Scared the crap out, which caused me to get new front tires (the back tires have ~10k miles on them). All 4 tires are Pirelli Scorpion Verde tires (not run flats). Unfortunately, the issue has not gone away.
